Quick SOHC Coupes?
Quick SOHC Coupes?
Where are all the quick coupes at? Im about to build the d16y8 for all-motor duty in my daily driven 97 EX and was wondering what everyone else is running and how they like it? Im going with a full Zex valvetrain (stock valves) and Zex stage 2 cam with some decent machining done to the head. Anyone know some numbers that I could expect? Also goin with a comptech header and thermal cat back with a carsound cat. Im excited for this project to get under way....hit me with your set-ups!
Re: Quick SOHC Coupes? (Rydaddy)
i went turbo so i can't help you in your na dreams but if you wanted my specs you can pm me and i can tell you how i got there
Re: Quick SOHC Coupes? (BlackNoise)
I HAD THE STAGE 2 CAM IN MY 99 EX AND I/H/E AND VTEC CONTROLLER 15.4 DON'T REMEMBER THE MPH , but unfrotunetly i didn't upgrade the valve train so i blew it up. since you are also doing head work i think you should hit high 14's with a good launch. the stage 3 is even crazier
[Modified by JSPECEX, 2:09 PM 3/9/2003]
Re: Quick SOHC Coupes? (JSPECEX)
Zex has a stage 3? I have only seen the stage 2. **** I'll get the stage 3 if there is one. I wanna get whatever the new valvetrain can handle.
Im getting the head work done at a local shop here in NorCal - Selby's Machine shop. Port n polish the head w/ port matched IM, full radius intake and 3 angle exhaust valve job, milled .020 and hot tanked.
Re: Quick SOHC Coupes? (h45454)
-SRR final drive (cuz even a sohc vtec is about no better then a integra LS tranny gear wise(ls tranny, all motor=sucks)
-d16a1/zc p29/pm7 pistons: high compression, over 12:1 in a d16y8.
-no mill on the head: might have valve piston contact
-y8 headgasket
-port/ polished head
-stiff valve springs
-stage 3 crower or exospeed sohc vtec cam
-skunk2 sohc manifold
-bisimoto header
-hondata s100/s200 ecu system
-gutted
-slicks
-tuned.
-y8 headgasket
-bisimoto header
-gutted
-slicks
-tuned.
Re: Quick SOHC Coupes? (JaeOne3345)
-y8 headgasket
-bisimoto header
-gutted
-slicks
-tuned.
-y8 headgasket
-bisimoto header
-gutted
-slicks
-tuned.
Re: Quick SOHC Coupes? (x lP lL i c i t)
no sometime here in march it should be out.
thats a theoretical set up. not mine,
builthatch dynod 164 at the wheels with a custom cam,headwork,and a1 pistons, ecu/afc, on a d16y8.
Currently.....Stock with I/H/E
In the works. (Yeah right more like a dream)
Goldeneagle block with 78mm bore.
JE 10:1 comp pistons
Eagle rods
Port and polish head
Brass valve guides
Stainless steel valves
Crower springs and retainers
Crower Stage 2 turbo cam
Port matched Intake manifold (JG Turbo kit)
Honda OEM 60mm throttle body
SSR 4.9 Final Drive
Clutchmaster Stage 3 clutch
Clutchmaster 8.5lb flywheel
JG/Edlebrock D series Carb legal turbo kit. (will get carb sticker on stock engine/turbo then drop the modified one in)
Custom B-Pipe in the exhaust with 3 catalytic converters to tell the sniffer to **** off.
Eagle rods
Brass valve guides
SSR 4.9 Final Drive
I've got a y8 with AEM Cold Air, APEXi GT Spec Header and GReddy EVO Cat back and my car still isn't really that fast...but that's cuz I have compression problems....I also have a d16z6 intake manifold and head for sale...ready for some head work if you need it....it's still in great shape.....
-y8 headgasket
-bisimoto header
-gutted
-slicks
-tuned.
-y8 headgasket
-bisimoto header
-gutted
-slicks
-tuned.
I have heard good things about the Zex cam for the d16..Im pretty much sold on the setup. I have to run on shitty Cali 91 octane so SUPER high compression is out of the question for me. Just lookin to give some DOHC's a scare...maybe even a spankin
i wouldnt get the zex cam if you are serious about being FAST FAST in a sohc coupe NA/all motor. get something bigger. and compression is your friend.
i wanna try carbs on a y7, dunno if thats the best idea.. but i asked RS machine about it and they said it could be streetable..
[Modified by Wazup, 10:28 AM 3/10/2003]
BoostinEJ1
52
05-03-2005 11:16 PM
Gant
16
01-09-2005 08:49 PM
zseeanz
06-24-2003 09:38 PM
