quick question about cam seal removal for b series
alright i got a golden eagle cam seal and i need to take off the old beat up stock cam seal which leaks how do i take off the cam seal i remove the two bolts and then what i tried getting a flat head screw driver but its a bitch to get off can anyone help?
Re: quick question about cam seal removal for b series (careawholelot)
nevermind searched and found out what i need to do thanks guys
ok now i can't get the god damn cam seal in this is ******* bs. piece of **** *** cam seal wtf how did you guys do it. piece of **** *** design
Re: quick question about cam seal removal for b series (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">are you reffering to the distributor side ex. cam seal?</TD></TR></TABLE>
yup that piece of **** side
**** i've been working on the stupid *** cam seal since 10:30 i have to be at work at 4 it is now 3:17 **** i hate this ****
Well if you are going to take off the old one, you are going to basically remove the exhaust cam, you have to take off the exhaust cam holders, then when you put it back together, you have to torque then down in a sequence.
9 5 1 3 7
8 4 2 6 10
1 being the middle top bolt, and 2 being the middle bottom bolt. First tighten down the bolts in this sequence to 8 ft lbs. Then after the bolts are tightend to that, in the same sequence, tighten the bolts to 16ft lbs. The outer bolts call for 7 ft lbs, just get them tight, not too tight though! This is all off the top of my head!
edit: The bolt sequence refrred too here is for the 12mm bolts, the 10mm bolt are the ones you just get tight! Good luck with work bro!
9 5 1 3 7
8 4 2 6 10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">what are you stuck on??? </TD></TR></TABLE>
It's not brain surgery! I did a whole headgasket swap last night in 3 1/2 hours on a 1g b16a? Start to finish! This is a cam seal, c'mon! I just gave you the hardest part of the deal! Whatever you do, don't just wrench down the bolts, hate to see you lose you head! haha... get it!
Re: quick question about cam seal removal for b series (mattssi)
no its not the exhaust cam its the cam seal right above the upper radiator hose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi »</TD></TR><TR><TD CLASS="quote">
It's not brain surgery! I did a whole headgasket swap last night in 3 1/2 hours on a 1g b16a? Start to finish! This is a cam seal, c'mon! I just gave you the hardest part of the deal! Whatever you do, don't just wrench down the bolts, hate to see you lose you head! haha... get it! </TD></TR></TABLE>
just curious, but did you have the head resurfaced?
well called work told them i can't make because both my cars are down
just curious, but did you have the head resurfaced?</TD></TR></TABLE>
It was the first time the head was ever removed, And it was low mileage, so no! I didn't, and guess what, It has about 400+ miles on it now, and no leaky leaky.. I thought that 3 1/2 hours was like way fast! I did two front axels on a 94si hb the day before yesterday in 45 mins!
Re: quick question about cam seal removal for b series (2lua)
well the golden eagle cam seal would not fit is was too big and no way in hell was that **** going in, also it chiped on the sides so there went $20 down the ******* drain i will never buy a golden eagle product again, went to acura dealer ship 50 miles away from house they had 2 different types of cam seals, they had the stock one and another easier one which the parts guy said works a lot better and was cheaper and better designed then what came stock. Got home took two seconds to put on and i didn't need to use any tools to put it on, and now no leaks. **** i am so tired but glad i got the job done, and didn't have to take my car to a mechanic to fix it.
What part number was the other cam seal you ended up getting? And how muc did you pay for it?
Re: quick question about cam seal removal for b series (sirminder)
I;m sure that he ended up getting the one that pops in, and doesn't have the inside ring, it just has teeth that grab the inside! Those are easier to install, but i like the ones with the inside ring, they last longer!
Yo I had a hard time too, its a cam seal it looks so simple, i ended up with a hole in mine and was shredding the whole thing up tryna get it out, heres what i did, 1.Take off valve cover
2. remove cam holder right near the seal
3. the whole **** should now be able to be lifted out
4. throw that piece of **** away
5. talk **** about homies mom
6. put new one in, start bustin VTEC
thats what i did, now it dont leak and half my motor isnt covered in oil any more
vlc92189
03-15-2007 05:34 AM
