Quick Question
Old 09-26-2008, 12:29 PM
Shaynepolevault's Avatar
Default Quick Question
Where is the first o2 sensor located? The one from the cel codes guide labeled o2a. I have a 1999 si want to know because i got a check engine light, and through a code 1 need to replace the o2 sensor.
Old 09-26-2008, 12:53 PM
Default Re: Quick Question (Shaynepolevault)
how many oxygen sensors are on a 1999 civic si? Are there only 2 one before the cat and one after?
Old 09-26-2008, 12:55 PM
solattack77's Avatar
i would think two since its obd-2
Old 09-26-2008, 12:56 PM
EJ8_Enthusiast's Avatar
yeah, 2. the back one monitors how well your cat is cleaning the exhaust.
the first one should have an adapter, the second just has wires that run up into the floorboard.
Old 09-26-2008, 01:00 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: Quick Question (solattack77)
one under near the half shaft, then one the cat
Old 09-26-2008, 01:37 PM
Default Re: Quick Question (HybridcivicLS-T)
When I do the cel check if there is 2 codes how long is the pause between the 2 codes? Because before i thought i was getting 11 now I think im getting 10 and 1. And does it matter the order. or am I suppose to get 1 first and then 10? Becasue right now im getting a long flash so 10 then a long pause the a quick flash so 1 Im guessing?
Old 09-26-2008, 01:40 PM
Former Moderator
B18C5-EH2's Avatar
You should really hook up an OBD2 scan tool and read codes from that.
The two wire jumper method used for OBD1 cars isn't always specific enough, and OBD2 cars throw codes that OBD1 cars don't so how will you use an OBD1 method to properly check those codes?
Although I hate Auto Zone they do free OBD2 diagnostic hook-ups with a scan tool - stop by one and have it scanned for FREE.
Just don't be surprised if they try to sell you their crappy parts to "fix" your check engine codes.
Old 09-26-2008, 01:55 PM
Default Re: Quick Question (B18C5-EH2)
So does anybody know how accurate the ob2 jumper plug method is for 1999 si if the code are right or not.
Old 09-26-2008, 02:13 PM
scbmx87's Avatar
Not very, take it to autozone and have them scan it...its free.
doubleoazn03
03-03-2018 02:06 PM
slabsquathrust
Honda Civic (2001 - 2005)
07-02-2013 05:32 PM
PPWLUDE
02-24-2010 11:21 PM
PPWLUDE
02-23-2010 04:40 PM
korney
11-04-2006 10:02 PM
Quick Reply: Quick Question
