Quick Question: 1992 Eg hatch SI D16A clutch replacement
Exedy Part# 08022
Make/Model 92-95 1.5L 1.6L
Disc OD 210MM
Spline Teeth 20
Hi guys i have found this specs on ebay for exedy clutch kit
am i looking at the right one since i have a JDM D16A Vtec (ZC)
i have also found disc OD 212mm, 220mm and OD 200mm
which one is the right one for me??
they all look the same but the size is different or if that even makes any difference
Thank you guys~
Disc OD 210MM
Spline Teeth 20
Thank you guys~
Re: Quick Question: 1992 Eg hatch SI D16A clutch replacement
according to the exedy website, it is
http://www.exedyusa.com/oe/Applications
i checked that too
but what does the diameter and spline teeth do?
oem replacement
Disc Outer Diameter 210mm (8-1/4in)
Spline Teeth / Major Diameter 20T / 7/8in
vs stage 1
Disc Outer Diameter 212mm
Spline Teeth / Major Diameter 20T / 22 mm
does that mean bigger diameter, the higher stage it goes?
and will i be able to use the 220mm one's? my buddy told me he has one from ek and was something like 220mm diameter
thank you
HBRIDER
18
10-28-2012 12:55 PM
97accordbuildlx
09-26-2011 01:51 PM
bennjamin@ozhonda.com
07-06-2005 09:19 PM
