Quick! is my hood latch support supposed to be bent? 95 hatch
Re: (siregcivic)
mins bent like that too but never thought much of it. Thatss weird its bent exactly the same way. Does anyone have a pic of theirs that is straight cuz its seems like its just the way it is.
Re: Quick! is my hood latch support supposed to be bent? 95 hatch (copperfox)
heres a pic of mine.. its also a little bent nothing like urs... id imagine thats what happens when u bottom out on the front end hard... if hit mine a couple of times.
to take the ac out... u need to take the car to have the freon drained... unbolt all the lines.. its not really hard.. just look at whats bolted down and remove it
Re: (EtherEG93)
Nah its easy to remove ac. Just loosen up the any part of the pipe just enought to hear it leak and leave it like that with hood open for like 2 hours to make sure its all out. The start taking it all off. Start by reming all pipes then canister and condenser and unplug the relays and stuff. Then remove compressor by removing it from braket off engine and belt will come right off. Its easy it took me only 30 minutes after discharge. Engine bay will look much cleaner and gain noticeable amount of power. Like night and day.
Re: (junior40er)
but make sure you save all that crap cause you can get good money for those things. I have tooken both off my eg civic and have them laying there cause I might want to replace em but if you wanna get rid of it let me know my friend wants to buy em for his eg. He has a jdm b16 with tons of bolt on so hes cool with losing a bit o power cause he doesnt race or anything. Just let me know how much with shipping to 90706
ya but its not good to drain the freon out in the open... just take it to a damn place they will drain it for u.. and if u get caught draining freon into air.. its a 1200 fine good luck
and you dont really gain any horsepower .. just a little in wieght savings ... like what 30-40 pounds.. and it doesnt use any horsepower unless its on.. i took mine out because im goin home made turbo and i want to put my side mount right there.. also my ac pump was fucked...
make sure you seal all the hoses and inlets on the compressor and stuff so they dont get contaminated in case you want to sell them or put them back on. ESPECIALLY seal the fittings that go into the car. if you leave them on the car, they will get so full of dust and ****. its not easy to flush if you want to put these pieces back on.
hugh_jazz_sponer
10-11-2003 12:06 AM
