QUICK! Mounts for B20 into EG!
Old 04-14-2004, 07:24 PM
Glen Tennis's Avatar
Default QUICK! Mounts for B20 into EG!
I finally lowered the B20 into the engine bay, all the mounts line up except the driver side mount. I am using the EG DX mount. It looked ok but its about an inch too high and there is no way to force it without having the engine be drasticaly lower on the driver side. What mount was I supposed to use?
Old 04-14-2004, 07:25 PM
rxse7n
Guest
Posts: n/a
The b series mount.
Old 04-14-2004, 07:47 PM
Mag00n's Avatar
Default Re: QUICK! Mounts for B20 into EG! (Rockinfunzone)
You are trying to mount a b20 in an EG with the stock eg mounts???
Old 04-14-2004, 08:11 PM
Eg9_fourDOOR's Avatar
Default Re: QUICK! Mounts for B20 into EG! (SICKSOLVTEC-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SICKSOLVTEC-T &raquo;</TD></TR><TR><TD CLASS="quote">You are trying to mount a b20 in an EG with the stock eg mounts??? </TD></TR></TABLE>
they did that with my fiends swap and the tranny mount snapped and dropped and snapped an axle and royally uckfed his stuff up. use hasport mounts or some other billet mounts at least B-series mounts.
Old 04-15-2004, 12:22 AM
bump
Old 04-15-2004, 05:11 AM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">bump
BUMP? What else do you want? You need to stop being a cheap *** and buy real Bseries mounts, Honda or aftermarket. End of discussion.
Old 04-15-2004, 05:30 AM
Hybrid96EK's Avatar
BUMP? What else do you want? You need to stop being a cheap *** and buy real Bseries mounts, Honda or aftermarket. End of discussion.</TD></TR></TABLE>
Yeah, no ****. Go get some 94+ Integra mounts or something. Put down the crack pipe. Stock EG mounts will not work.
Old 04-15-2004, 05:48 AM
degooser's Avatar
Default Re: QUICK! Mounts for B20 into EG! (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, no ****. Go get some 94+ Integra mounts or something. Put down the crack pipe. Stock EG mounts will not work.</TD></TR></TABLE>
the stock one will work if its sliver and looks like the integra one...
Old 04-15-2004, 10:35 AM
Thats the point, I didnt know I was using the wrong one until I lowered the motor in and saw it was out of whack. Its not like Im still trying to make it fit with the wrong one.
Modified by Rockinfunzone at 11:47 AM 4/15/2004
Old 04-17-2004, 03:48 PM
Ok I found the problem. The previous owner put some other mount bracket on that was way too high for the mount. For the record, a Civic DX one will work, try it out and see before opening your pie hole.
Old 04-17-2004, 03:58 PM
Jawad.'s Avatar
your avatar explains everything.
Modified by John Kerry at 1:45 PM 4/20/2004
Old 04-17-2004, 04:12 PM
JeffS's Avatar
What you should be using in an integra driver's side mount and swap the B20 mounting bracket (attached to the side of the block) with one from an integra.
Old 04-17-2004, 04:40 PM
biassj's Avatar
All 94-95 Civic uses the 94-01 Integra timing belt mount. 92-93 has a diffrent mount.
Recyclingfreak
05-06-2017 08:27 PM
...esteban
03-31-2008 03:51 PM
mustang5.slow
14
05-26-2007 11:22 PM
MurdersV8s
09-14-2006 04:56 AM
lowntegra
Northeast (Sales)
06-23-2006 08:15 AM
Quick Reply: QUICK! Mounts for B20 into EG!
