Quick Master Cylinder Question
I've searched but haven't found a straight answer. Is there an oem or aftermarket 1" MC that will fit on to a dx booster?
Re: Quick Master Cylinder Question
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/4-disc-brake-swap-questions-ek-2679146/ - This will explain the propotioning valve
As for the MC you can get a 96+ GSR one which will fit but your brakes will be hard so if you want the altimate brakes you should consider changing the MC and boost from the teggy. Lines will line up with no problem.
I have a ctr 5 lug swap and its a dx which means it still uses the 40/40 proportioning valve i believe. Is the 96+ an abs set up?
Did you read the other thread about the PV???
The PV are the same except the 4 doors and this will apply to the CTR.
Instead of worrying about the PV you should consider upgrading the booster.
In other words leave the PV alone and yes the MC is one for the teggy with ABS.
malubawla
20
04-09-2007 04:28 PM
