Quick and Easy VX Upgrades?
I was just wandering what kind of cheap and easy hp/tq upgrades are out there for a vx? I have an EX intake manifold but I need a tb
put an ex/si intake and exhaust manifold , and you will gain a damn 9 hp its well worth it , dyno proven too ad more when you run it with p28 and adjustable fuel pressure regulator
Re: (92b16vx)
i put a p28 ecu into a vx, it threw a code for some weird reason, but it pulled a little harder plus it reved higher., but other than that b18c-typer
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">D16Z6 transmission is the best mod you can do to it</TD></TR></TABLE>
That motor is never going to be super strong. The block is weak, as are the rods. Just get the power to the ground a little more efficently and you'll be a lot better off.
Former Moderator
Re: (BauleyCivic)
Echo that.
The Si/EX tranny will be the best mod.
If you are on a tight budget I'd just do either a D16Z6 (92-95 Si HB and EX 4DR, 93-95 EX coupe) full engine/tranny swap, or get a JDM ZC SOHC VTEC swap.
As Ricey stated, the VX engine is just weak - period.
Echo that.
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">As Ricey stated, the VX engine is just weak - period.</TD></TR></TABLE>
ahhh crap. so doing a junkyard turbo setup is pretty much out of the question then? im in the same boat as the original poster. i won't have the money to really do anything big to this car for a long time. i was planning on making a turbo kit for it peice by peice over the summer, and have it running by next spring. my life sucks.
Former Moderator
Re: (ninefivehatch)
I would never ever boost the VX engine. The rods/pistons are so weak I'll bet that 5psi could easily destroy the engine, especially untuned.
Re: (B18C5-EH2)
damn, well that throws my reasoning out the window. i was thinking that because the engine is designed to run lean in low rpm's it would be built stronger. so much for that logic. im really glad i found this before i put a turbo on, becuase this is my only transportation. thanks.
Re: (B18C5-EH2)
Just a note - the block/crank/rods are the same as the JDM D15B SOHC VTEC. Don't completely discount the Z1 - it just needs lotsa love and most parts from a Z6 to make it a nice little performer. Rods are longer (137mm) and thicker (don't have specs...yet) than the other 1.5L - not counting the D15B. Good r/s ratio with the shorter stroke and longer rod length. Here's a pic of the VX/D15B rod (P08) left vs. a B7 rod right:
Transmission would be the best upgrade, as said. How far you want to take after that it is up to you -
Finding the best pistons for the combo would be the hard part - Z6's have been rumored as an option along with D17 GX (high comp.). No one I know has slapped this combo together - yet. A few are in work though.......
Re: (ninefivehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninefivehatch »</TD></TR><TR><TD CLASS="quote">damn, well that throws my reasoning out the window. i was thinking that because the engine is designed to run lean in low rpm's it would be built stronger. so much for that logic. im really glad i found this before i put a turbo on, becuase this is my only transportation. thanks.</TD></TR></TABLE>
Z6 swap will be a good platform for you to build on. It's less expensive than a junkyard turbo setup as well.
Btw, those rods look like toothpicks.
Re: (Ricey McRicerton)
But they are larger toothpics
Sure they will limit ultimate output - but just because there not the "best" doesn't mean that they wouldn't be good in a specific application. If you are shooting for over 200whp, look elsewhere.
This would be a good little N/A screamer/commuter built right -
N20 is right out.
N20 is right out.
Re: (civicminded92)
so a d16z6 would be pretty much plug and play in a 95vx using the d16z6 engine harness. i searched for a little bit, and thats what i came up with. can someone confirm that. my next question is, can a z6 handle mild boost form a junkyard turbo setup? most likely a t25, or 14b DSM turbo, at like 8 psi. higher if it can handle more. thanks for the help. i want to apoligize to the original poster for thread jacking, but its about the vx, so i think it will be ok. if you would like me to take this to a different thread, i can.
edit. if i buy a jdm d15b longblock (motor, intake and exhaust mani's, injectors, fuel rail, throttle body, alt., dis., and tranny) what else would i need? the only thing i can think of is engine wiring harness, and a ecu to control it.
Re: (ninefivehatch)
im on the same boat also...thinking about doing some minor mods to my vx but kinda low on the budget. How much would i gain with a ex intake manifold? would the gains also be noticable? thanks
Former Moderator
Re: (meanTheDope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanTheDope »</TD></TR><TR><TD CLASS="quote">im on the same boat also...thinking about doing some minor mods to my vx but kinda low on the budget. How much would i gain with a ex intake manifold? would the gains also be noticable? thanks</TD></TR></TABLE>
Dude I'd do the tranny first and foremost.
Make all the power you can with the D15Z1, but that VX tranny will still kill anything resembling acceleration.
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Re: (B18C5-EH2)
i just got done with my homemade turbo setup for my 94 vx.running 5lbs on a straight t3 .60 .48. fmic, and 450s and VAFC. runs strong. pulls hard.dont under estimate the Z1
nice job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicminded92 »</TD></TR><TR><TD CLASS="quote">Just a note - the block/crank/rods are the same as the JDM D15B SOHC VTEC. Don't completely discount the Z1 - it just needs lotsa love and most parts from a Z6 to make it a nice little performer. Rods are longer (137mm) and thicker (don't have specs...yet) than the other 1.5L - not counting the D15B. Good r/s ratio with the shorter stroke and longer rod length. Here's a pic of the VX/D15B rod (P08) left vs. a B7 rod right:
Finding the best pistons for the combo would be the hard part - Z6's have been rumored as an option along with D17 GX (high comp.). No one I know has slapped this combo together - yet. A few are in work though.......</TD></TR></TABLE>
nice job
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">JDM ZC SOHC VTEC</TD></TR></TABLE>
Would like more on this... this is the same as a JDM D15B, correct... any specs? where to pick one up?
Re: (BauleyCivic)
basically u need to switch out everything but the head.
get z6 fuel rail. manifold. tranny. p28 ecu.
i put a p28 on my vx when i had the vx engine.
and it pulled when it hit vtec alot harder then when the vx ecu was in.
Former Moderator
Re: (ninety5vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninety5vx »</TD></TR><TR><TD CLASS="quote">
Would like more on this... this is the same as a JDM D15B, correct... any specs? where to pick one up?</TD></TR></TABLE>
No, it's a 1.6L JDM version of the 92-95 D16Z6. It simply says "ZC" on the block, but it is a SOHC VTEC engine.
Re: (Jokerluv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv »</TD></TR><TR><TD CLASS="quote">i have a Z1 also </TD></TR></TABLE>
me 3. going out soon for the b-series (non-vtec )
