Quick, Easy Question.
Re: (MichaelJComputer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">Huh? They are held on by set screws.</TD></TR></TABLE>
I know, but are they considered slip-on, or bolt-on, it's a $65 difference to get them rotated.
I can't afford that 65 dollar difference.
Re: Quick, Easy Question. (Goullish)
You will more than likely need an impact screwdriver to get the philips head screws out.
Other than the retaining screws, just undo the bottom bolt on the caliper and swing it up. You can now pull off the pads and rotor and replace.
Re: Quick, Easy Question. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">You will more than likely need an impact screwdriver to get the philips head screws out.
Other than the retaining screws, just undo the bottom bolt on the caliper and swing it up. You can now pull off the pads and rotor and replace.</TD></TR></TABLE>
Not able to do it myself, no garage, or tools.
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">i would think that they are slip on, cause it is just 2 screws that hold it in place. bolt ons are like accords.</TD></TR></TABLE>
Ok, thanks.
Ok, thanks.
Re: (Goullish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish »</TD></TR><TR><TD CLASS="quote">
I can't afford that 65 dollar difference.</TD></TR></TABLE>
You mean 'turned'? They basically need to know if the rotor comes off for the lathe or they need to use the in-car lathe, right?
I believe Honda uses an in-car lathe.
So how much are you getting charged for new pads and the rotors to be turned?
OEM Honda pads ~$40
New Brembo blanks ~$30/each
OEM Honda pads ~$40
