Quick: Do I need to drain the tranny when pulling the motor?
It's been a while since I've done a swap. I'm pulling the b16b (motor and tranny) today and would like to avoid any unecessary steps. Thanks
Re: Quick: Do I need to drain the tranny when pulling the motor? (2-7offsuit)
If you do not and the motor is to come out the top then it will leak the transmission oil out of the axle shaft locations. It is so easy to do (1 bolt), why not?
Re: Quick: Do I need to drain the tranny when pulling the motor? (tpr)
DONT DRAIN IT.
Just watch the fluid spill everywhere as your pull your motor out.
Panic FTW
Panic FTW
R.I.P.
Re: Quick: Do I need to drain the tranny when pulling the motor? (Filliam H. Muffman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Filliam H. Muffman »</TD></TR><TR><TD CLASS="quote">DONT DRAIN IT.
Panic FTW</TD></TR></TABLE> lol
Re: Quick: Do I need to drain the tranny when pulling the motor? (honda 3300)
don't need two drain the tranny fluid, just changed the cluch on my 95
2 mounths ago....pull the tranny off..
..put new cluch in....put tranny back on,
also just pulled a blown motor in my CRX...
..the tranny is sittin on my garage floor still full of fluid
if some drains out, then you will need to fill it back up so why not replace with new fluid while you have the perfect opportunity?
HGZ
11-12-2008 04:55 PM
