Quick distributor timing question [pics]
One of the cylinders on my car are missing, and I think it might be the distributor timing. I looked at it and it looks like its all the way advanced, is it supposed to be this way? Is there any way to adjust this without a timing light?
sorry the picture is kinda blurry, but this is looking at one of distributor bolts
Re: Quick distributor timing question [pics] (TurboDaveR)
if its a stock motor oem timing will be right about the middle, best thing you can do is get a timing light and do it the proper way, you wont know by just moving it around. also i dont think that would really attribute to your cyl missing, check the plugs and wires, i never had an issue with timing causing that problem.
Get a timing light and fix it. Cant you rent one from autozone, use it for 5 seconds and give it back. I think its free too.
Electrician
Same thing happened on my friend's car. His distributor was all the way advanced. It ran like **** and somettimes hardly started. Turned it to the middle and started her right up.
Get a timing light and set it to spec.
Risky Business
Re: (Dimi)
You can't gauge by looking at the dizzy where stock timing is, it depends on the cam timing. Most motors are slightly different. Use a timing light so you can get 16 degrees BTDC. What kind of motor is it?
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">16 degrees BTDC.</TD></TR></TABLE>
hate to be a nag but every book ive ever seen on a honda said 12 degrees BTDC.
maybe for forced induction that is where it is supposed to be
Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">
must be looking at something else, Most CIVIC's have always been 16 +/- 2 degrees.
HTn00b
03-10-2007 10:17 AM
