Quick 5 lug conversion Question
Had trouble searching since it doesn't find the 5 in "5 lug conversion" while searching. I have a 96 civic hatchback and I have the CTR 5 lug conversion I know I need the prop. valve from an SI, and I'm getting brake lines from an SI. I was wondering if I needed lower control arms from a SI or are they the same as the CX, and DX civics? Also I did a bit of searching and someone said you have to use 98-01 Integra Brake booster, and master cylinder why 98-01? and not 94-01 anyinfo anyone could give would be great! Thanks guys!
Re: Quick 5 lug conversion Question (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You can use your stock LCAs. You will only need the Si LCAs if you want to mount a rear sway bar. </TD></TR></TABLE>
Cool, makes sence! Thanks! Anyone know about the Master Cylinder and Brake Booster? Thanks!
cayman_hatch
08-18-2005 11:30 AM
