questions regarding my ek dx hatchback rear disc conversion
Questions regarding my ek dx hatchback rear disc conversion
hi, i'll be doing a rear disc conversion soon on my 00 dx hatchback. i got the swap kit and proportiong valve from importautosalvage.com, without the master cylinder. is it necessary for me to get a new master cylinder too(if yes, would the ex-nonabs one work?)? also can i use the original e-brake cable on my dx with the new setup? thanks.
Re: Questions regarding my ek dx hatchback rear disc conversion (opera936)
you do not need to change your master cyl.
i didnt even change my porp valve. i just got 99-00 si rear disc's and trailing arms and bolted them up. never had a problem yet. brakes bettern then drum brakes.
you need a ebrake cable for a disc brake setup the dx will not work
you don;t have to replace the master cylinder/booster but you should..
you can always do it later
you going to need master cylinder and brake booster for 99-00 si
integras ones might work just make sure the lines attach to the master cylinder in the same spots.and its from a non-abs car (all 99-00 don't have abs)
its varies year to year.. some will have the lines on the right or left or top in different combinations..
Re: Questions regarding my ek dx hatchback rear disc conversion (gezzuzz)
Civic EX and SI master cylinders are the same I believe. The older integra ones won't work but, the newer ones, newer than 96 I believe are a straight bolt on. I have a 00 Type-R MC I bought new from honda on my EK/EJ. It bolted right on. It's got the largest pistons of civic compatible MC's (1" I believe).
My research showed that the SI and CX/DX prop valve had the same part # from Honda so, I didn't bother swapping. I used E-brake cables from an 00 SI.
Re: Questions regarding my ek dx hatchback rear disc conversion (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">
My research showed that the SI and CX/DX prop valve had the same part # from Honda so, I didn't bother swapping. I used E-brake cables from an 00 SI. </TD></TR></TABLE>
thats is good to know.. i guess we changed my boys for noithing
so a new master cylinder and proportioning valve is unnecessary, but a "new" e-brake cable is mandotary? also can canyone tell me where i can get it online? and also it has to be a cable for the car i got the trailing arm from, or would any of si cables will work(del sol si, si coupe, wat about the ex ones)? thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opera936 »</TD></TR><TR><TD CLASS="quote">so a new master cylinder and proportioning valve is unnecessary, but a "new" e-brake cable is mandotary? also can canyone tell me where i can get it online? thanks in advance.</TD></TR></TABLE>
Ebrake cables is not mandatory if your swap came with ebrake cables already.
For a rear disc conversion you don't need a MC/BB from an Si, stock is fine. Also, the stock prop valve is the same as the Si.
I used the same cables from the 99-00 Si in my 98 DX hatch and they worked just fine.
i wanted to use 94-00 integra trailing arms complete with the hub and all on my ek ex so alls i need is si brake cables and thats it? no prop valve?
Re: (opera936)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opera936 »</TD></TR><TR><TD CLASS="quote">so as long as it is an e-brake cable from ANY 96-00 SI model, will work?</TD></TR></TABLE>
99-00 Si, there was no 96-98 SI.
ok i got the whole assembly with the ebrake cables...but now do i need the si break lines?
if the si and cx/dx prop valve is the same,what about the civic coupe ex?i also want to swap drums to disc and i dont know if i need the prop valve form the si?
Re: Questions regarding my ek dx hatchback rear disc conversion (boostin_dc2)
i thought all i need was the e brake cables from the si, i got that confused with the brake lines. do i need brake lines from the si in order to finish this conversion? any help would be greatly appreciated. thanks.
fryman
08-07-2015 06:49 PM
