Questions on axle, tire rubbing, Teg brakes on EH2
I am a (Trial User) Army
Hey guys,
Well, I’ll be replacing my passenger side axle next weekend. I looked at it last weekend and I think it’s snapped in the boot. Ever since I installed my H&R sports and KYB AGX’s (installed 1 month ago) I’ve been experiencing tire rub on the passenger side when I turn to the left. I don’t ever rub on the driver side. Do you think the bad axle is causing the rubbing?
Also, when I replace the axle next weekend I’m going to be putting on Integra front brakes. Would it be alright to run teg front brakes with my stock mc and bb for the time being? How will the pedal feel? Will it be safe?
I’m sure I’ll have follow up questions as the week progresses about minor things, so I’ll continue to update the thread.
Thanks,
George
Thanks,
George
Re: Questions on axle, tire rubbing, Teg brakes on EH2 (litterbox)
i have the setup on my EK, my axle was also busted, replaced the axle yesterday, doing the timing belt, water pump, thermostat, and dualcore radioator. itll be hopefully up and running tonight or tomrorw. i can give more info after it runs again.
you can use ur stock MC/BB and prop valve for now. but consider upgrading it soon. pedal feel will be more or less stock. just make sure you bleed it real good.
