questions about my turbo set up!!?
ok i have a 93 ex with a d16z6 with a dx tranny longer gears..i have 270cc injectors,map sensor cheater,manually retarded the timing,and have a chipped p06,,and im running 8 psi also has a new hondata head gasket and cleaned internals with only 85k miles could this be used as a daily driver?any and all helpfull stuff is appreciated
Re: questions about my turbo set up!!? (zachsbat1)
First off yes it can be, but you'll have to lose the map sensor cheater, get a GM 3 bar or something to handle you boost if the stock one wont, and get it tunes right. That should be all you need.
Re: questions about my turbo set up!!? (tturbocivic0618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tturbocivic0618 »</TD></TR><TR><TD CLASS="quote">get some dsm 450's maybe instead of the 270's? </TD></TR></TABLE>
dsm's will require a resistor box, you can do that. But it will be easier to get saturated 450's (or desired cc's) from rc or someone.
CO_HaTcH
07-18-2006 12:39 PM
