Question on Tuning...
Are there shops that will tune your car if you buy say a JET chip or v-afc?
and also, does the type of chip you get matter if you have a manual or AT
what is a good chip for AT and good chip for manual.
Re: Question on Tuning... (TrunkRattlin)
a good tuner can tune a vafc or a chip. I would recommend the chip since it actually alters the fuel maps and doesn't just alter the signal the ecu sees from certain sensors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrunkRattlin »</TD></TR><TR><TD CLASS="quote">what is a good chip for AT and good chip for manual.</TD></TR></TABLE>
a good chip is a chip tuned for your specific car. any other chip is a bad chip. Every motor is different, buying a chip online with modified fuel maps designed around someone else's car is asking for trouble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrunkRattlin »</TD></TR><TR><TD CLASS="quote">so if i were to buy hondata, can i take that to a tuner and ahve them tune it for me?</TD></TR></TABLE>
Yep. It doesn't matter if its hondata or uberdata, as long as your tuner knows what he's doing you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrunkRattlin »</TD></TR><TR><TD CLASS="quote">what kind of shops will do this type of tuning?
that all depends on what is local to you. tuning on the dyno would be your best bet.
http://www.hondata.com/
Re: Question on Tuning... (IHateJDM)
i went to hondata.com, and becuase i am new to "tuning" i do not understand what the difference is between the chips...sry
S100 = chip burned with new fuel/ignition maps for your car.
S200 = S100 + datalogging capabilities (download info from car's sensors to pda or laptop to see what its doing).
S300 = S200 + real-time programming (change fuel/ignition maps on the fly).
There is a little more to it than that, but those are the biggest differences.
First thing you should do is find a tuner in your area, tell him/her your set up, price range, and see what he/she wants to do. They'll prolly tune you with crome, which is the best, hondata is just extra wasted money to me.
Crome is a program to make the maps to burn the chips, check out http://www.pgmfi.org Sure to find a tuner and more info there. Crome is free, CromePro (what a tuner will prolly use) is like 150.
Re: (SVOboy)
The hondata wont work with the AT tranny... So what if i got a Jet kit and sent them my ecu after i insert the supercharger? is JET good with ECUs? Anyone have expeirence with them?
Modified by TrunkRattlin at 2:23 PM 12/28/2005
Re: (SVOboy)
Where are you located? If your so cal i could get you started then point you in the correct direction. If you have a wideband i could street tune you.
Powered By Garrett
Engine Management and Tuning
11
07-04-2008 08:44 AM
