Question swap info: H22 into an eg.
* B A N N E D *
Are there companies that make wiring harness conversion kits, that would make it possible to plug and play this whole swap. If so, what are the url's. Thank you.
* B A N N E D *
Re: Question swap info: H22 into an eg. (unbelievableEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbelievableEG »</TD></TR><TR><TD CLASS="quote">why would you need to change the wiring harness?</TD></TR></TABLE>
I was told there was cutting and splicing to do. If a company made a harness that plugs to the firewall(civic) and to the h22 without any modifications that would be a conversion.......
Re: Question swap info: H22 into an eg. (aquabob89)
Maybe this is what your looking for
http://www.boomslang.us/
When I bought my H22, it was originally swapped into a 93 hatch, so it the wires that came with were already plug and play... I suppose you could try and find what you're looking for, but I've had to do some rewiring on mine to get the vtec to work. (I used the H series injectors with a CRX resistor box.) It's always cheaper to moddify the existing wires.
