Question on oil leakage
My Z6 is leaking oil from the left side of the head on to the tranny. Would the head just need to be tightened or do I need to replace the head gasket. Are any others doing this?. I had seen one thread where someones looked like mine?
Thanks
Thanks
Re: Question on oil leakage (Caveman74)
Z6, thats VTEC right? Ill put money on it that its your cam seal. I got the same problem with my GSR motor. They cost like 10 bucks and take 15 mins to change.
http://importnut.net/STRseal.htm
Thats for B series but you get the same idea.
Re: Question on oil leakage (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Z6, thats VTEC right? Ill put money on it that its your cam seal. I got the same problem with my GSR motor. They cost like 10 bucks and take 15 mins to change.
Thats for B series but you get the same idea. </TD></TR></TABLE>That's what I was thinking, I hope that's all it is, but if you do have to remove the head let that be reason build internally.
Vice President/CEO
Re: Question on oil leakage (SILINITY16)
those cam seals are sorry little buggers.. i wish i had tried that first before thinking it was my head gasket' UGH!! What a pain. - Try that seal and let us know.
Re: Question on oil leakage (kKdARIAN)
I'll get a pic when I get off work. It looks to be coming from the back corner by the solinoid. The bolts are tight on the solinoid. the head is pretty new, so i'm thinking it might be loose on that side.
Risky Business
D-SERIES DO NOT HAVE CAM SEALS ON THE LEFT SIDE THEY HAVE DISTRIBUTOR O-RINGS
There was a thread about a week ago about this leak
https://honda-tech.com/zerothread?id=700456
Turned out to be the distributor o-ring for 90% of us. Its a $2.00 part from honda.
Risky Business
Re: Question on oil leakage (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">It is most likely your vtec solenoid gasket. I had the same problem on my B18c1. I replaced the cam seal and still had the problem. I replaced the vtec solenoid gasket and it has been fine for almost a month.</TD></TR></TABLE>
This is true, but I dont think any of us SOHC guys had that problem.
Re: Question on oil leakage (BauleyCivic)
Thanks Bauley. I think that is what it is. I replaced my distributer a while back. I'm just going to spray it down and double check the leak. It has to be some sort of ring or gasket. That pic looks just like mine. But it is leaking onto the back side of the tranny. I'll post the pic and let the pros choose!!
-Whitey-
27
11-09-2002 10:41 AM
