question bout speedometer
Old 12-16-2015, 09:03 PM
spaceghost530's Avatar
Icon3 question bout speedometer
i have a 95 dx eg civic coupe with a d16z6 and p28 ecu. ever since i got the car the odometer stopped and the speedometer hasnt worked. how would i go about fixing this. what part(s) do i need if any.
Old 12-16-2015, 10:04 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: question bout speedometer
Is your VSS plugged in? Is your CEL on? Does it work?
Old 12-17-2015, 08:16 AM
Icon5 Re: question bout speedometer
yues my vss is plugged in. my fuel guage works, temp guage works but odometer and trip dont work, and neither tdoes the speedodometer i dont think its the cluster. any ideas?
Old 12-17-2015, 08:17 AM
and no cel is not on but srs is
Old 12-17-2015, 09:32 AM
NotARaCist's Avatar
Does the CEL work? It should come on for 2 seconds when you turn the key to ON(II), then turn back off.
Old 12-17-2015, 09:36 AM
Man U FTW
Schister66's Avatar
Does it go into VTEC? If the VSS is truly unhooked and the speedo/ odo is the problem, the car shouldnt go into VTEC. The speed sensor, in combination with oil pressure, give the 'ok' for that to happen.
Old 12-17-2015, 09:44 AM
Yea it works when started. Cel that is and I'm not sure how to know if vtec kicks in
Old 12-17-2015, 09:46 AM
Actually cel doesn't lite up at all when started
Old 12-17-2015, 09:50 AM
NotARaCist's Avatar
Replace the bulb, pull the codes, and we can work from there.
tthoj
26
02-04-2010 04:41 AM
f22bsedan
09-09-2009 04:22 AM
imskatencrzy
12-18-2006 11:46 AM
stolen4drteg
12-15-2004 09:44 PM
junya16
03-05-2003 08:42 AM
Quick Reply: question bout speedometer
