Question about GSR swap into an Si
A friend of mine has an Si with a B18c1 swap. It's been swapped a long time ago, but just recently it started idling really bad. When you start it up it idles high, then about 5 seconds later it starts idling high and low, high and low, and doesn't stop. If anyone knows anything about this, please let me know soon. Thanks
Re: Question about GSR swap into an Si (FastGirlRacer)
what kind of SI.
which year model ?
when was the last time he did a tune-up, changed this timing belt ??
which year model ?
Former Moderator
Depending on what year that B18C1 is, it could be:
1. Coolant level.
Being low on coolant will cause an irratic idle. Check the simplest/cheapest things first
2. Fast idle valve. This was found on the 1994-1995 GS-Rs and possibly on some later models. This valve is located on the bottom side of the throttle body. It has a few coolant hoses going to it, and it regulates the idle when the motor is cold.
Inside of this valve is a spring loaded plate that shuts on/off depending on coolant temoerature going through it. Most likely the plastic plate inside of the valve has come unscrewed. You can take the end cap off of the FIV and put some Hondabond on the plate and rethread it back in place.
3. Electronic Air Idle Control Valve.
This is located on the intake manifold itself. This part is way more expensive and is unlikely to be your problem.
1. Coolant level.
First he should check all vacuum lines, make sure nothing is disconnected or riddled with holes. Adjust the idle screw on the throttle body, see if it makes a difference. Expensive scenario: could be a bad Idle air control valve (IACV), or Fast Idle Thermo Valve.
Re: Question about GSR swap into an Si (B18C5-EH2)
Also, supporting Tom's with the low coolant. Make sure there is little if NO bubbles inside the coolant system. Simply "burp" the system by making sure the car is completely cold.
Take off the radiator cap, then turn on the car. Allow the car to fully warm up with the radiator cap off. Let all of the air bubbles out, also squeeze the bottom & top radiator hose to get all the air bubbles up and make sure the coolant levels as well as overflow is at proper levels.
HTH.
HTH.
1. Coolant level.
1. Coolant level.
Re: Question about GSR swap into an Si (poison)
well I (robert) have a jdm b16 in a 95 sol, and we have changed out the eaic valve because the computer was signaling this item. so lets narrow it down a little.
the coolant has happened to me, so that will be next/ if you can explain more on the fast idle valve... it's on the bottom side of the tb?
that could be possible and we have checked most vaccum lines,nada
thanks for your quick responses!
remove the t/b and then remove the 2 8mm bolts on the back side and remove the plate. you will see a big white screw inside. use a quarter to tighten it all of the way. install t/b back and bleed coolant.
Former Moderator
Again I say the FIV is the most common idle-related problem aside from bad vacuum routing.
The FIV is held on with some 12mm nuts I believe. The end cap is gold colored and is held on with two phillips screws,
Remove the FIV by removing those 12mm nuts and then you can inspect the insides by removing that end cap with the phillps screw driver.
If the white plastic piece (flat big-*** plate) is loose inside, then simply dab some RVT sealent or Hondabond on the edges and screw it back in and adjust the idle with the idle mixture screw to compensate for the new position of the plate in the FIV.
If the spring inside os bent or broken, then just buy a new FIV.
Former Moderator
Re: Question about GSR swap into an Si (BCRUZspec)
You can remove it w/o having to remove the TB in most cases, but just in case order a TB gasket anyways.
Removing the TB is easy as hell, but that gasket can cause some headaches.
Robert again here...
so the fiv is actually a part on the bottom of the tb, and just inspecting/replacing, possibly just tightening it will more than likely fix. now about bleeding the coolant
there is no bleed valve that I can find like on my sol. So I guess We'll try the burp method ____ thanks again guys
Eurasia00
04-22-2002 11:37 AM
