question about distribuators?
what is the difference between a 92 cx distribuator and a 93 ex distribuator . also are the automatic distribuators different then the manual ones . or can i just use any distribuator from 92-95 hondas ? thanks
be professional
Re: question about distribuators? (hondaon18's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s »</TD></TR><TR><TD CLASS="quote">what is the difference between a 92 cx distribuator and a 93 ex distribuator .</TD></TR></TABLE>
They are not interchangeable. The VTEC and non-VTEC cylinder heads have different bolt patterns for the distributor mounting arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also are the automatic distribuators different then the manual ones .</TD></TR></TABLE>
No, no difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">or can i just use any distribuator from 92-95 hondas ? thanks</TD></TR></TABLE>
What model you you have?
If CX, DX, or LX, you can used any '92-95 distributor from those models.
If VX, EX, or Si, you can use any distributor from those models.
What is wrong with your existing distributor?
No, no difference.
Re: question about distribuators? (Targa250R)
well i have a cx and the problem is that the oil got inside of it becuase the gasket was no good anymore. so now you know how the rotor suppose to spin when you take it out my does not want to move it jammed . all i see is that the parts that makes rotor spin is rusted. so the car still starts it just that it runs crappy. so i was wondering if i can replace it with a ex one from a 93 .
be professional
Sounds like the bearing failed, so you do indeed need an entire new base.
You cannot use a distributor from an EX on your CX. You need a distributor from a '92-95 CX, DX, or LX.
yep thats my problem. but how come i cant use from a ex . if you don't mind me asking. they told me that i can use any one of the 92 thru 95 civic model distribuators
Modified by hondaon18's at 1:22 PM 8/18/2007
The CX, DX, and LX modles dont have a VTEC head on the engine and if u try to use a dizzy from an EX, VX, or ,Si the bolts will not line up As Targa250R already mentioned
Modified by TooManyTickets at 2:39 PM 8/18/2007
SDT Project EF
09-26-2004 04:30 PM
5thgencivic
13
10-31-2003 06:13 AM
