Question about disk brakes???
does the 92-95 civic hatch SI brake set up, all the way around, same as 94-up integras? how about the prop. valve? is it worth the change over on the GSR's? thanx for the help guys.
Re: Question about disk brakes??? (JDMallmotaEG)
1992-95 rear disc is the same as 1994-01 integra
front brakes on si hatchbacks are 9.5inches
front brakes on integra are 10.3inches
Re: Question about disk brakes??? (eg6sir-s)
thank you sir. how about the prop.valve? so is it worth replacing the fronts with the integ? thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallmotaEG »</TD></TR><TR><TD CLASS="quote">thank you sir. how about the prop.valve? so is it worth replacing the fronts with the integ? thanks again.</TD></TR></TABLE>
the stock prop valve you have on you si hatcback(30/40) should suffice. just make sure to upgrade your brake booster(non-abs integra model) & master cyclinder(non-abs integra model).
streethondar
01-13-2011 05:49 AM
boost and bass
07-15-2009 02:56 PM
Civicman86
12
04-30-2007 10:40 AM
