question about clutch master cylinder
if i am swapping my motor will i need to get a clutch master cylinder for my car or for the motor that i am going to put into my car which is a b20/vtec
Re: question about clutch master cylinder (motrayEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motrayEG6 »</TD></TR><TR><TD CLASS="quote">if i am swapping my motor will i need to get a clutch master cylinder for my car or for the motor that i am going to put into my car which is a b20/vtec</TD></TR></TABLE>
no you don't need the M/C from the engine. what ever civic you have, continue to use the M/C for the year/model civic.
now if you want to replace it for maintenance purposes then by all means.
well i am haveing trouble finding a master cylinder for my year civic so is there any other type of honda vehicles or acura vehichles that i can buy the clutch master cylinder for and have it fit on my 92 civic hatch CX
Re: (motrayEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motrayEG6 »</TD></TR><TR><TD CLASS="quote">well i am haveing trouble finding a master cylinder for my year civic so is there any other type of honda vehicles or acura vehichles that i can buy the clutch master cylinder for and have it fit on my 92 civic hatch CX</TD></TR></TABLE>
you mean to say you can not find a M/C for a 92 civic in missouri? any part store or dealer can supply you with one.
if not here are some links i provided:
http://advanceautoparts.com/
http://www.thehondapartsstore.com/
if you want to upgrade without having to modify your brake lines, a 91 civic ex will bolt straight to your lines and booster, anything else will need modification.
92-95 civic (cx, dx, lx (non abs)) 13/16"
91 civic ex 15/16"
91 civic ex 15/16"
Re: (motrayEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motrayEG6 »</TD></TR><TR><TD CLASS="quote">if i want to upgrade what all do i need can u tell me or someone is it just like steel lines and **** or what</TD></TR></TABLE>
you should have a stock M/C. the current measurment of the cylinder is 13/16"
the bigger you go the better braking and pedal feel you will get. but going to big without the proper brake assembly will not be beneficiary.
since you are doing a crv-vtec, i suggest that you can upgrade to a 15/16" M/C. this upgrade will work great with your current stock brakes without having to swap out your brake booster or bend any of your brake lines. even if you go with a disc setup like the ones found on integras, abs civic's and del sols (no you don't need abs) it will be an upgrade from your current M/C.
if you wanted to go bigger than the 15/16", there is of course the itr M/C which is 1", but you will need itr brakes, booster, as well as bending you brake lines, which i do not recommend you try this.
search through this link:
https://honda-tech.com/zerothread/642479
it should be very helpful!
MoogieBoogie
17
08-12-2013 11:53 AM
ZenDynasty
24
06-01-2008 07:56 PM
