question about brake setup
1 Post
first of all i have a 92 civic si with erything stock...ok heres the deal....i got tboned on my passesenger side back in december. well that messed alot of **** up.when i went to get an alignment, they said my spindle is bent and my lca needs to be replaced also. so i got a price on a spindle which was $100. i have a full integra brake setup with the spindles and rotors and all that good stuff, heres my question..can i just put the integra complete setup on my car instead of spending 100 on a spindle??? any help will be appreciated
Re: question about brake setup (D16Z6_turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6_turbo »</TD></TR><TR><TD CLASS="quote">Yep! but you have to use the integra e-brake cables.</TD></TR></TABLE>
No you don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec »</TD></TR><TR><TD CLASS="quote">first of all i have a 92 civic si with erything stock...ok heres the deal....i got tboned on my passesenger side back in december. well that messed alot of **** up.when i went to get an alignment, they said my spindle is bent and my lca needs to be replaced also. so i got a price on a spindle which was $100. i have a full integra brake setup with the spindles and rotors and all that good stuff, heres my question..can i just put the integra complete setup on my car instead of spending 100 on a spindle??? any help will be appreciated</TD></TR></TABLE>
Is the front or rear damage. If your talking about spindle that the front right.
No you don't.
1 Post
i have rear disk, so im not doing anyhting w/ the rear at all
what are you trying to say???? yea it is damaged on the front right, supposedlym the spindle and lca is bent
Re: question about brake setup (pgpunkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy »</TD></TR><TR><TD CLASS="quote">the front brakes off an integra won't work unless you have a B-series engine... (different axle splines)</TD></TR></TABLE>
Wrong, you are talking about jdm type r with 32mm or some **** like that.
Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C »</TD></TR><TR><TD CLASS="quote">as long as your use the entire front spindle from the integra setup, it'll fit. </TD></TR></TABLE>
brake booster not so much, but master cylinder? definately. it isn't required, but when you eventually do it you'll kick yourself for having not done it earlier. get a '91 civic ex sedan mc.
1 Post
Re: (Mike C)
i heard that since the spindle is a lil bit longer that it will throw my camber off...is this true? and if it is i do have and omni camber kit so will i be able to adjust it to the right camber even with the bigger spindles??
1 Post
Re: (poptik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poptik »</TD></TR><TR><TD CLASS="quote">get the big brake brembos!</TD></TR></TABLE>
i think they require 17's and they look retarted on my small car....take a look at my pics
