Question
Question
Can I put y7 clutch, flywheel and pressure plate in a cable si tranny? Seems like it would be the same for y7, just need someone elses opinion.....heres the quote.
Clutch, pressure plate and flywheel…The 90+ setups have a wider surface area then the 88-89 therefore offering more contact area and thus more effective power transfer. The Z6 with stock clutch, pressure plate and flywheel will bolt directly onto 89+ year transmissions. It will not bolt directly onto an 88 transmission unless the proper 88 clutch, pressure plate and flywheel are used (due to the 88s having a different spline count on the input shaft). 92+ transmissions can’t be used due to them being hydraulically activated, and the mount positions on the 92+ transmission being different then the ones on the 88-91 transmissions.
Gant
08-04-2004 06:43 PM
