Question 2.5" collector pipe to 2.3" exhaust on d16 will it work?
Old 10-04-2010, 02:10 PM
Trick311's Avatar
Default Question 2.5" collector pipe to 2.3" exhaust on d16 will it work?
Running a WSII exhaust 60mm, about 2.3" catback exhaust with a 2.5" High Flow cat and stock y8 exhaust manifold. Im lookin at getting the Tri Y header 4-2-1 that rins to a 2.5" collector pipe. Will this require me to increase the size of my exhaust system?
Going to be running a stage 2 ZEX Cam in december with springs and retainers
Old 10-04-2010, 05:49 PM
canadaek's Avatar
Default Re: Question 2.5" collector pipe to 2.3" exhaust on d16 will it work?
sounds plenty big enough for a N/A D16
Old 10-04-2010, 05:51 PM
fv8s's Avatar
2.5 is plenty for a d16. no need to get carried away
Old 10-05-2010, 06:33 AM
Trick311's Avatar
So your saying I would have to increase the pipe size of the system? I cant have the drop from 2.5" collector to 2.3" catback?
Old 10-05-2010, 10:21 AM
Red_Army's Avatar
you could but the flow might not like the funneling into a smaller size piping.
Old 10-05-2010, 11:04 AM
jdmjay82's Avatar
im just curious what type of intake are you running ?
Old 10-05-2010, 12:39 PM
Trick311's Avatar
2.5 inch custom made intake. Mandrel bent pipe cut into proper pieces to run, coated with textured heat resistant paint on outer surface and gloss heat resistance pain on inner with K&N filter. During winter, pipe stays cool with driving all day, different story in summer. 100 degrees out here in summer
Also running upgraded fuel system at a higher pressure with a GSR throttle body and ported intake
Raatzio
06-08-2005 09:12 AM
JoeB18R
12-14-2004 11:48 PM
crx1856
06-25-2003 01:41 AM
scooby_dooby_doo
08-30-2002 10:05 AM
Quick Reply: Question 2.5" collector pipe to 2.3" exhaust on d16 will it work?
