Question
Old 03-08-2007, 12:03 PM
jit01's Avatar
Default Question
Hi I got a question I have a 95 del sol vtec with a b16a3 motor in it (came stock) I want to get skunk 2 stage 1 cams I was wondering will I need a tune ? or can I drive without a tune for a bit ? Also do I have to get cam gears ? and will my idle be the same as stock ?
Old 03-08-2007, 12:06 PM
philosofy1's Avatar
Default Re: Question (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">Hi I got a question I have a 95 del sol vtec with a b16a3 motor in it (came stock) I want to get skunk 2 stage 1 cams I was wondering will I need a tune ? </TD></TR></TABLE>
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote"> Also do I have to get cam gears ? and will my idle be the same as stock ? </TD></TR></TABLE>
no you don't need cam gears and yes idle would be about the same.
Old 03-08-2007, 12:07 PM
jit01's Avatar
Default Re: Question (philosofy1)
Thanks a lot. If I do get cam gears would it make much diff ? and if I get it tuned would it be worth it ? I will be using crome.
Old 03-08-2007, 12:52 PM
been there done that
doood's Avatar
if you want to get the most out of the cams despite their relatively small size you will need cam gears and a tune
Old 03-08-2007, 01:51 PM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Cam alone aren't going to do much.
Old 03-08-2007, 01:59 PM
jit01's Avatar
Default Re: Question (JDM-EJ1)
ok right now I have an aem short ram intake, aem pulleys, and catback twin loop exhaust. I am going to get a blox intake manifold, header then the cam and cam gears with a street tune or should i dyno ?
Old 03-08-2007, 02:33 PM
doood's Avatar
do both
aych2h
07-23-2007 08:35 PM
b16a4
04-01-2007 05:17 AM
Teamdiesel
16
06-29-2006 11:29 PM
blkwidow420
04-14-2005 01:37 AM
vteec
06-23-2004 12:30 AM
Quick Reply: Question
