quaife install now a leak
installed a quaife differential and replaced my axle seals and i still have a minor leak, anyone have any advice or have ever experienced this problem? the motor is an ls with an ls tranny and yes the differential i bought was made for an ls and i did replace the seals and i did seal the case back up . so dont ask any of those questions just need to know if anyone experienced theirs leaking or any tranny leak and what you did to stop the leak. The first time this happened to me my tranny got locked in gear from having a leak and i dont want that to happen again
Re: quaife install now a leak (B20 EJ6)
axle seal area but i have repeatedly checked the seal and it is good, not a lot is dripping but i wipe the area anytime before i leave my house and when i get home i wipe my hand in the whole general area and i feel little bit of oil and it is only dripping from the passenger side of the tranny
Re: quaife install now a leak (team703)
Had the same problem with my gsr hydro trans. No matter what I did it still leaked. I finally got oem seals and that somehow fixed it. I compared the oem to aftermarket and they looked identical. The spring is different though. You probably get the burnt oil smell if you run it out correct?
Try Dealer seals
Try Dealer seals
Voodoo7
04-02-2012 01:17 AM
92-LS-Civic
18
08-20-2005 12:09 PM
