Putting my swap in soon...wire harness
I have a 98 ex coupe. I am putting a 95 b18b1 in this weekend or next. Just verifying that I use my stock wireharness on the b18b1 motor, and plug it into the obd2-obd1 wireharness adapter, and plug it into the ECU. Thanks.
Re: Putting my swap in soon...wire harness (civcexcoupeblack)
yes, use your stock harness. But you will probably need to extend quite a few plugs. Just be prepared, SOLDER all wires and cover with heatshrink.
New User
http://tech.hybridgarage.com/t....html
Here is a helpful link. Make sure your harness has the proper wires for vtec...
B18C1 in EG Civic
Check on the following 7 lines to see if everything is there and if they are hooked up right.
Engine Side ECU Side
Desciption Wire Color Pin/Connection
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V power (hot in ON or START)
Evap Purge Solenoid Red A20
Secondary Intake Solenoid Pink/Blue A17
B18C1 in EG Civic
honda dan
19
12-03-2012 09:16 AM
projecthonda
02-23-2007 06:48 PM
