Putting ABS onto my '98 Hatch?
Re: Putting ABS onto my '98 Hatch? (CheezeFrog)
Anybody ever put ABS into a non-ABS car? What parts are required?
Re: Putting ABS onto my '98 Hatch? (b16b hatch)
Why ABS is ghey and a waist of time.
your best bet would be to pull the entire system out of a EX with ABS, it will be front wheel only though I think.
IT will be a big pain in the *** though cuz you will have to get all of the hard lines in the engine compartment (may have to remove your motor to put them in too), and your car might be missing the harnesses for it.
Then make sure to get ALL the wires and sensors from the knuckles and stuff too
Tonyx, thanks. It looks like I'm going to have to find out the hard way just how difficult it's going to be.
b18b hatch, you can stop a LOT quicker with ABS than you can without. Even F1 cars use it. Now unless you're a lot better driver than your average F1 driver, I'd say ABS can only help
Bull:
1. Why ABS is ghey and a waist of time.
2. it will be front wheel only though I think
3. I sure that none of the 8 Sec. cars use abs either ABS is a joke just use GSR brakes not ABS. Cheezefrog
Ok. First off - it's been done by someone on this board. He showed it off in Richmond - 1992 Civic Hatch - excellent job.
It's A LOT of work. There's multiple parts that have to be swapped into the car. I'll just BEGIN a list below.
Second - ALL Honda anti-lock brake systems have been three channel or more. This includes ALL FOUR wheels. All of 1996 and up ones I have seen have been four channel, but it is my understanding from my reading that there ARE still three channel ABS's floating around on Japanese made USDM Integra's. I have NOT seen these.
Third - ultra fast cars don't use ABS. Well, ultra fast DRAG cars DON'T use ABS. They also don't use taillights or airbags. Who gives a crap, though? The reason they don't use ABS is WEIGHT. ABS makes cars stop quicker - period. A lot of people, myself included, don't use them on our performance cars because under certain circumstances you WANT the brakes to lock (drifting or rallying), and the systems do add significant weight. If you want better daily driver brakes, ABS is a great ticket to do so.
Down to tacks - stuff you'd need to do it:
Suggestion: Buy a totaled and stripped EX chassis with brake system still intact. That had been suggested, but you'll need components from all four wheels. This applies if you don't want rear discs - if you're going to this much trouble though, you might consider using the REAR components from an ABS Integra (98 and above) and get yourself rear dics.
1. Master cylinder and booster - your old one MIGHT drive the system - but Honda put an extra big booster and reservoir in the ABS Civics for a reason, didn't they?
2. Underhood hard lines - ALL
3. Proportioning valve from ABS car
4. Hard lines from underhood components to wheels - they could be spliced or custom bent - but it could be very difficult if you haven't done this
5. ABS sensor from ALL four wheels, with harnesses and wires.
6. ABS axles with gears on front
7. ABS discs/or trailing arm assembly/or ABS drums on rear
8. ABS servo motor from underhood
9. ABS brain (processor) from ABS car
10. Wiring harnesses to hook it up. I don't have personal experience from an 6th generation hatch, but the fifth generation hatches lacked ALL the wiring harnesses for ABS.
11. Dash module from ABS car - i.e. entire dashboard module if you want the ABS light to work properly (i'll admit, I know that this is needed for fifth generation hatches, but MIGHT not be needed for sixth generation hatches).
There may be more, or less, but these are the COMPONENTS you'll need - some of them MIGHT already be present on your car, but I don't think they are.
Shawn
Holy **** that helps out a lot! Thanks a ton, Shawn!
Shawn
agaf'd
15
04-03-2009 01:35 PM
