B20b into a 99 ex
Old 07-04-2005, 12:56 PM
Supa_Slow_Civic's Avatar
Default B20b into a 99 ex
I'm about to do an b20 swap into my civic....is there any problems I'm going to run into with the swap
Heres my part list:
JDM B20B
LS Tranny
99-00 Si motor and tranny mounts
P30 ecu
GSR Axles
GSR Half shaft
Should I have any problems using any of this....If you can help that would be great
Supa_Slow_Civic is offline
Old 07-04-2005, 12:57 PM
e jay one's Avatar
Default Re: B20b into a 99 ex (Supa_Slow_Civic)
search.
e jay one is offline
Old 07-04-2005, 01:01 PM
FlatBrokeHatch's Avatar
Also check your states emmisions. Its a light truck motor...some guys have trouble getting it cleared in a car.
FlatBrokeHatch is offline
Old 07-08-2005, 09:58 AM
rev2nine's Avatar
I have a b20 vtec teg. It was an easy swap because I didn't have to change much of anything around. b18 to b20 , its all the same. You will need to add a wiring harness to your list also. keep us posted on the project
rev2nine is offline
Old 07-08-2005, 02:21 PM
B18C1 '96 Coupe's Avatar
Default Re: B20b into a 99 ex (rev2nine)
Why P30 ECU? Why not run a P75? Also i thought the IM was to tall on B20, do you need an LS intake manifold? Your Harness should be ok, you may need to extend wires.
GSR Axles will be fine I run them on my LS swap GSR trans. I would recomend either doing the 3M window weld trick or gettign the ES/prothane tourqe Mount bushings. I hate breaking that drivers side upper mount. It realyl is an easy swap. I would recomend it over a B16 for sure.
Yes it is covered under search but I thought i would be helpfull as much as i can.
B18C1 '96 Coupe is offline
Old 07-08-2005, 06:40 PM
Default Re: B20b into a 99 ex (B18C1 '96 Coupe)
Well I have the p30 right now so i can go vtec but im going to get a ls ecu.....I'm also going to be using an ls wire warness.....I will keep you posted on it...should have some pics for you soon
Old 07-13-2005, 10:41 AM
Your using a LS Harness in an EK/EJ chasis? It wont mount to the ECU. The EK/EJ harness goes from the motor to the ECU, the DC Harness goes to Other Harnesses.
Your wiring Harness will work fine you will jsut need to extend some wires and possibley for ease of use switch some plugs.
Old 07-17-2005, 12:03 PM
What wire harness will i need....i dont really want to cut and rewire things
Old 07-21-2005, 12:37 PM
D15Bbigred's Avatar
how does this apply for a 93 ex any differences, not too jack thread
D15Bbigred is offline
Old 07-21-2005, 01:12 PM
illustrator's Avatar
if your gonna do a CRVtec setup in the future.. might as well get a 99-00 civic si engine harness.. just don't plug the vtec line.. and then get a P75 ecu.. OBD2B to OBD1 ecu harness... LS intake manifold... I would also upgrade your driverside mount... to a PLace racing one if you find one.. or a Hasport...
illustrator is offline
Old 07-12-2018, 04:37 PM
Daniel99's Avatar
Would the B20B IM not fit in an 99 Ex ? Do I have to run the 94-01 Ls Intakemanifold ?
Daniel99 is offline
Old 07-12-2018, 09:07 PM
JRCivic1's Avatar
If you leave the hood off or cut a huge hole in it... the B20B I/M works. If you want a hood and want to keep rain off the engine... you will need an LS style I/M.
JRCivic1 is offline
Old 07-12-2018, 11:03 PM
Stancetard Hate Monger
eghatch9295's Avatar
make your own thread or search, this swap has been done thousands of times. don't necro dead threads from '05
eghatch9295 is offline
Old 07-12-2018, 11:28 PM
Daniel99's Avatar
But when I make my own threads , you say negative things ? Or some will say find a thread about it already. Which I did so I wouldn’t make anymore threads and now you’re complaining?
Daniel99 is offline
Old 07-13-2018, 10:50 AM
Fish Twig
tony_2018's Avatar
You didn't even specify which b20 you got.
tony_2018 is offline
kchavira520
10-21-2014 07:09 PM
bettsbanger
09-19-2009 12:09 PM
hondajav06
12-06-2006 11:17 AM
danny_ha
08-28-2006 07:59 PM
thehatchninja
12-31-2002 09:50 AM
Quick Reply: B20b into a 99 ex
