Pulsating pedal after changing rotor?
Old 07-07-2010, 09:35 AM
averyvm's Avatar
Default Pulsating pedal after changing rotor?
Changed both rotors on my 93 hatch and I still have a pulsating pedal that goes with the speed of the wheel.
I've installed two new Autozone rotors with relatively new Autozone ceramic pads and the pedal still vibrates and makes a squeking noise at low speeds.
Any help would be appreciated
Old 07-07-2010, 09:58 AM
Former User's Avatar
Default Re: Pulsating pedal after changing rotor?
Maybe the old pads should be replaced.
Old 07-07-2010, 10:07 AM
averyvm's Avatar
Pads still got meat on them u still think I should replace them?
Old 07-07-2010, 10:11 AM
Just some thoughts:
Maybe the old warped rotors damaged the current pads?
The squeaking brakes also could indicate incorrect re-installation of the old pads. The worst case scenario is that this has warped the new rotors.
Old 07-07-2010, 10:15 AM
averyvm's Avatar
What would you use to grease the pins that the calipers slide on?
Old 07-07-2010, 10:19 AM
itsmejto's Avatar
Did you clean off the rust from behind the rotors with a wire brush.
New disks, always use new pads, regardless of how they look.
Dump the ceramic pads and get some sensible ones.
EBC GreenStuff work well for none maniac driving.
Old 07-07-2010, 10:23 AM
Silicone grease
Old 07-07-2010, 10:33 AM
averyvm's Avatar
Never heard of those pads where's the best place to buy 'em. And thanks RonJ@HT
NuRon
03-10-2008 05:51 PM
shotgun2224
10-09-2007 11:37 AM
nhlfan
08-23-2005 02:33 AM
mr tl
09-20-2002 08:22 PM
Quick Reply: Pulsating pedal after changing rotor?
