Pulling motor out. Need help on....
I'm about to pull my motor out and YES i did a search. I found everything on how to do it except for one thing...where to hook the cherry picker to on the motor. i am pulling out a d16z6 out of my cx if that helps. please post pix. TIA!!
Re: Pulling motor out. Need help on.... (Synergy001)
I put one side of the chain on the driver side upper motor mount and the other side on (memory loss...) the...ummm...crap...somewhere near the distributor.
put one hook on the alternator bracket and te other on one of the loop bracket on the tranny..that is if you chain have a hook on each end..
if it just a chain then use a 14mm or 17mm which ever bolt and hook it to the same place that i just mentioned...
Re: Pulling motor out. Need help on.... (C uR eX)
i used a bolt on the side of the head i think and the other one i used the tranny bracket...
Pulling the motor up was hard for me because of ac compressor hitting.. So I just dropped it from the bottom and pulled it out.
Re: Pulling motor out. Need help on.... (b18bcx)
same, i use a bolt in the head near the dist. and i go under the mount on the drivers side. all the ways posted sound good though
Re: Pulling motor out. Need help on.... (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">Do yourself a favor and buy yourself an engine leveler.....they work wonders.
Re: Pulling motor out. Need help on.... (Aceman64)
I pulled my z6 by myself one night, and did not have one problem. Check out the helms. Find the last top right bolt on the driverside where the PS bracket is. Now look on the back side of the head, There will be a hole with no bolt in it. Just put a thick bolt through there. The other spot is on the tranny. It is a brass color loop, that you basicly just hook something to that. And as everyone else said, buy a leveler. I bought mine for $25 and it was worth every penny
Re: Pulling motor out. Need help on.... (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">I pulled my z6 by myself one night, and did not have one problem. Check out the helms. Find the last top right bolt on the driverside where the PS bracket is. Now look on the back side of the head, There will be a hole with no bolt in it. Just put a thick bolt through there. The other spot is on the tranny. It is a brass color loop, that you basicly just hook something to that. And as everyone else said, buy a leveler. I bought mine for $25 and it was worth every penny</TD></TR></TABLE>
cool...what size bolt will i need on the head?
yep, I think that I might have used the PS bracket mount bolt on the exact oppisite side of that hole, since I was not going to use PS anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">yep, I think that I might have used the PS bracket mount bolt on the exact oppisite side of that hole, since I was not going to use PS anyways.</TD></TR></TABLE>
i never used power steering...so i guess ill see if i can find a bolt from another part of the motor
1 Post
theres usually a bolt hole behind the head right next to the t-belt cover, and the other side use the loop bracket as mentioned before on the tranny.
edit: looks like soneone already said exactly what i did
woo hoo...finally pulled my motor out today all by myself. i did it in 4 1/2 hours non-stop without power tools. not bad for my first time. the only problem i had was that my neighbor's cherry picker was low on oil and so i couldn't lift the motor to clear the front. i had to carry the motor and rest it on the support frame, move the cherry picker back and then carry it out again to finally get it out. i only scratched the front bumper a lil bit but the bumper already has big gashes from rocks on the road anyways, so i wasnt upset at all.
Guest
Posts: n/a
Re: (Synergy001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synergy001 »</TD></TR><TR><TD CLASS="quote">woo hoo...finally pulled my motor out today all by myself. i did it in 4 1/2 hours non-stop without power tools. not bad for my first time. the only problem i had was that my neighbor's cherry picker was low on oil and so i couldn't lift the motor to clear the front. i had to carry the motor and rest it on the support frame, move the cherry picker back and then carry it out again to finally get it out. i only scratched the front bumper a lil bit but the bumper already has big gashes from rocks on the road anyways, so i wasnt upset at all.</TD></TR></TABLE>
Congrats man
Glad to see that everything went ok
Congrats man
Re: (EJ1_519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_519 »</TD></TR><TR><TD CLASS="quote">
Congrats man
Glad to see that everything went ok</TD></TR></TABLE>
thanks....im glad everything went ok too. i was kinda paranoid at the beginning but i was motivated to get it out...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Term President »</TD></TR><TR><TD CLASS="quote">
Nice, what are you dropping in man?</TD></TR></TABLE>
im saving up for an ITR motor. but for the mean time i'll be driving my 93 si or my ram truck.
Congrats man
Bipolarcivic
08-23-2011 04:26 PM
rayzian
06-16-2006 05:52 PM
