PSI Low port AC Question
Old 12-21-2013, 09:25 AM
rovafa2002's Avatar
Default PSI Low port AC Question
Hi I bought a can of EZ Chill recharge and I am having some doubts about Low port PSI and outside ambient temperature.
In some threads I read that if having 90-95F I should be reading pressures below 30PSI.
However If I check RON's thread about AC I understand that when having 86F I should be reading 57PSI. Is that ok?
I meassured my car and at 86f I am seeing 37PSI.
I dont know which way to take, I havent done anywhing. My AC is not blowing any less that 60F and I know it should be around 40F.
Thanks!!
Old 12-22-2013, 04:34 AM
rovafa2002's Avatar
Default Re: PSI Low port AC Question
Bump, sorry but in the southern hemisphere is getting way hot now
Old 12-22-2013, 05:11 AM
Technical Hero
HondaPartsHero's Avatar
Have you checked out this one
https://honda-tech.com/forums/showth...0177&styleid=2
Old 12-23-2013, 03:16 AM
rovafa2002's Avatar
Hi There,
I have checked it out but I think I dont understand it quite well.
Step 5.6 is the one that generates confusion on me...
The temp doesnt seem to fall between those lines. I havent been able to get less that 50F on my AC and I see many people get 40. The best I did was 45 jumping the Thermostat but the day was kind of cold so I dont think its the thermostat itself. I did tested it in an iced watet cup and it was ok.
Old 12-25-2013, 07:15 AM
rovafa2002's Avatar
Bump
mizle
06-23-2012 06:11 PM
Corporation
09-25-2005 03:51 PM
Quick Reply: PSI Low port AC Question
