Proportioning valve question
I have a 92 VX hatch... my prop valve is a 30/30 i am installing rear disks in a few weeks.... do i need to run a 40/40 prop valve or will my 30/30 work? also is the 30/30 the same size as a 40/40 because i have a brake line tuck and i dont want to have to run the lines again for the 40/40.. like is the ends at the same positions? thanks
Re: Proportioning valve question (Ep1dem1c)
yes you need th 40/40 and yes it will bolt in. just try to find one out of an EG Si. or buy one from one of the online honda dealers. they are about as cheap new as getting one from a junkyard
Re: Proportioning valve question (DiyCarGuy)
so the 40/40 and the 30/30 are the exact same size and design? the only difference is the internals of it?
Re: Proportioning valve question (kaiba)
front are staying stock except for crossdrills for now... until i can afford a set of stoptechs or spoon's
GSRCRXsi
Suspension & Brakes
09-12-2010 06:17 PM
