The proper way
The proper way
well im starting to gather parts for my lsvtec and i was wondering what would be the proper way to begin my ls vtec build im looking to boost it after my build is done money is to big of a factor just looking for ides and before you say it i already did search just looking for more ideas thanks in advance
Re: The proper way (v!taminb16)
well if u r looking for about a decent streetable set up. id suggest just rebuilding the bottom end with new seals, gaskets, rings, bearings, washers, pumps etc... id also suggest getting ARP 8mm rod bolts and having those installed along with having the rods alignhoned back to OEM spec (should cost u around $1000). easiest way to really do the conversion IMO is get the Golden Eagle ls/v full conversion kit, its like $350 bucks but it comes with everything (special dowl pins, headgakset, oil filter sandwich plate, feed line, AN fittings, and anything else that is needed). upgrade your oil and water pump to GSR/Type R pumps along with a gsr/type r timing belt.
Re: The proper way (TayTeg91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TayTeg91 »</TD></TR><TR><TD CLASS="quote">well if u r looking for about a decent streetable set up. id suggest just rebuilding the bottom end with new seals, gaskets, rings, bearings, washers, pumps etc... id also suggest getting ARP 8mm rod bolts and having those installed along with having the rods alignhoned back to OEM spec (should cost u around $1000). easiest way to really do the conversion IMO is get the Golden Eagle ls/v full conversion kit, its like $350 bucks but it comes with everything (special dowl pins, headgakset, oil filter sandwich plate, feed line, AN fittings, and anything else that is needed). upgrade your oil and water pump to GSR/Type R pumps along with a gsr/type r timing belt. </TD></TR></TABLE>
Winner winner chicken dinner.
thanks for the help right now i have a rebulit block and im hopefully getting rods and pistons next paycheck and water pump and oil and timing belt also
thats cool man. just make sure u take it to a machine shop to have your piston to wall clearances checked for heat expansion of the pistons. and keep the directions to the rods that u r going to use becuase they will call for a different torque spec than OEM.
also check out the rod numbers that u have (1-4) if u r getting eagle rods, those rods call for a #3 rod bearing. so if u have a 1,2 or 4 rod u need to find out what bearing is for a #3 to us for those rods. but if u r going with the ACL bearings just have a machine shop measure all of the clearances for u.
yyourb0yy
12-12-2012 06:42 PM
