Problems getting into gear when engine is cold
I just got my ACT XTSS and ACT Flywheel installed but that isn't the problem. I don't think.
Before I got it installed, in the mornings when the engine is cold my clutch pedal would have little or no resistance. When it was like this it would be hard to get in gear.
But after I would drive it around a little and the engine would warm upn and it would go back to normal but not all the way.
Anybody got any ideas?
Re: Problems getting into gear when engine is cold (willyboyD16)
What tranny fluid are you using?
Have you checked your clutch master cylinder?
Which ACT flywheel? 8.8 or the 12?
Re: Problems getting into gear when engine is cold (wothatch)
It is the 12lb model.
F#@$ it. I am just going to change the master and slave cylinder.
r1de4life
11-19-2006 06:36 AM
