Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!!
Location: Santa Ana ES in 415 NORCAL where clean ricers are found :P
I'm cheap ok, college student = not much money to spend....so I bought a set of cheap adjustable coilovers in andysautosport.com .....I didn't know how to install them so I took the car to a shop to get my coils install.....They are install now but at the same height
This is what happened: the guy told me if I wanted to go low...which is what I want....the spring would be lose and is going to be rattleing and making noise, and if I leave it like that I can fck up the suspension and more sht down there ...WTF?? and then he told if I wanted to lower it I had to get some kinda of springs which are smaller to fit between the spring and the red rubber spring gap(see picture below)
This picture is exactly what is happening to me rigth now....if you guys don't get it I'll make try to make a better explanation.
Re: Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!! (Imp-tuner)
It sounds like you have the type that has a helper spring (like the Weapon Rs) only, you are missing that spring?????
Re: Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!! (jdmturbo1127)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbo1127 »</TD></TR><TR><TD CLASS="quote">It sounds like you have the type that has a helper spring (like the Weapon Rs) only, you are missing that spring?????</TD></TR></TABLE>
I guess I am ......where can I get it ??? I'll appreciate the help.
yeah, you got a short spring, and you're going too low.
if you had a reputable spring, like ground control, i'd tell you to ask them for a longer spring.
or if you had a good shock l ikea koni, i'd tell you to put your perch at a higher setting.
but since you have *****, then i ain't got ***** to tell you mate.
get yourself some better equipment my friend.
who ever did the work has never done this before. the springs will not be loose. they are alot shorter than stock, so they do not reach the top of the shock, but once you have them on the car and lower the car off the jack, it will compress everything together like it suppose to be. sometimes you have to guide the spring a little as you lower it, so it sits properly. but once the car is on the ground your fine.
so this is what you need to do. jack up a wheel, take it off, use the hook tools to lower the spring perch to where you want it. this is very easy,you can do it. then lower the car slowly.
Like 2redstars said, it will all compress together and be fine. But if you do have the type with 2 springs and you're missing one, you're probably going to be very low.
You bought a cheap piece of **** -- get some real coilovers or a shock/spring combo...
Ground Control
Skunk2
Good Tokicos
Ground Control
Skunk2
Good Tokicos
Re: (2redstars)
word. what kind of place did you take it to? the coilover spring is gonna be way shorter than a stock spring. even a drop spring for that matter. turn the perch as much as you want. lower the car slowly and make sure the springs sitting in right.
make sure you count the turns when lowering the perch so you can match it on the other. what i use to do was lower them all the way down, then spin them back up and count.
goodluck
goodluck
shoulda gotten some tein s-techs...i have em on my 99 ej8...you cant really tell its lowered, it MAY be only lowered about .75 inches...but the ride is a lot nicer than stock.
its your vehicle, dont compromise....bad **** happens when you do!
If you wanna give that a shot, I have some weapons Rs laying around in the garage. 20 bucks, theyre yours
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">word. what kind of place did you take it to? the coilover spring is gonna be way shorter than a stock spring. even a drop spring for that matter. turn the perch as much as you want. lower the car slowly and make sure the springs sitting in right.
goodluck </TD></TR></TABLE>
Thats the worse part I took it to WORKS MITSUBISHI guys who prepare EVOS for racing...they even prepared an evo for time attack ..... http://www.worksevo.com/ thats the website they are in San Rafael... Damn
Anyways-here are some pics after the coils got install....
Sorry for the pics I couldn't turn them around
most of you are damn retards...the spring only sits up against the top hat when its not compressed if the suspension is preloaded. when the car is lowered and driving it will all compress together. get a new mechanic who isnt dumb and dont listen to ht bandwagoners
Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">who ever did the work has never done this before. the springs will not be loose. they are alot shorter than stock, so they do not reach the top of the shock, but once you have them on the car and lower the car off the jack, it will compress everything together like it suppose to be. sometimes you have to guide the spring a little as you lower it, so it sits properly. but once the car is on the ground your fine.
so this is what you need to do. jack up a wheel, take it off, use the hook tools to lower the spring perch to where you want it. this is very easy,you can do it. then lower the car slowly.</TD></TR></TABLE>
AGREED, couldn't have said it better myself.. 2redstars
H-T White Ops
Re: Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!! (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">most of you are damn retards...the spring only sits up against the top hat when its not compressed if the suspension is preloaded. when the car is lowered and driving it will all compress together. get a new mechanic who isnt dumb and dont listen to ht bandwagoners</TD></TR></TABLE>
Somebody gets it.
Everybody that said that there were springs missing and that was the reason everything was loose.......have you ever done any suspension work?
BTW, OP, your ride quality is going to SUCK, and more than likely your stock shocks are going to blow within a few weeks.
Somebody gets it.
Re: (melsers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsers »</TD></TR><TR><TD CLASS="quote">you took your honda to a mitsubishi specialist?</TD></TR></TABLE>
Pretty much, but I went there 'cause they have a nice sign that says
Specialists in Mitsubishi, Toyota.......and HONDA!!!!
maybe not that specialized
Works definitely knows their Mitsu ****, but they most have had a rookie on your install. Some full coilover setups have two springs to them, but those are few and far between. Yes, the ride quality will get worst over time...but intially you'll have fun with them. Just raise up a side and lower the perches (if they provided spanner wrenches, use them) until happy. Avoid potholes like the plague and be careful when entering lots at varying degrees. Enter them like a low-rider...cross-ways.
Re: Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!! (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">
BTW, OP, your ride quality is going to SUCK, and more than likely your stock shocks are going to blow within a few weeks.</TD></TR></TABLE>
hope u like to redo work, cause ur shocks aint gonna last.
Re: Problems with Coilovers Pics inside!!!!!! HELP ME PLEASE!!!! (Malakai)
Cheaping out on suspension is probably the most retarded thing a person can do to their car. It would be like cheaping out on a doctor and going to a third world country to get operated on, just to save a buck.
Either get something that is quality or dont get it at all. Just because you have no money and are in college doesn't make sense to do something like that. Save up and then buy. Now youre further away from buying some quality suspension.
Hood4real
05-06-2010 05:20 PM
