problems with cluster (gsr) in hatch...
wired it up using the diagram everyone uses but nothing works, It is an obd2 cluster would this have anything to do with it? Do I need an obd1 for my hatch?
Re: problems with cluster (gsr) in hatch... (infamousRRH)
i had a jdm itr im my ek. i dont really know as far as obd goes. did u use http://www.merritr.com? thats where i learned to wire mine. anyways, sorry about the lack of help, good luck.
Re: problems with cluster (95CivicEX)
check my post above...it will explain everything
and the fuse that you will blow the most is #25....i blew it 5 times installing mine
Re: problems with cluster (J-MiGiRL702)
yes you have a EK obd2 w/ obd2 cluster Im guessing, I have a obd1 car and trying to use a obd2 cluster I think that is the problem.
Re: problems with cluster (infamousRRH)
here you go man.. i know for a fact this wiring diagram works correctly.. ive done it 2x's w/ no problems.. if it doesnt work its cause the cluster is broken or you did something wrong.. let me know
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used unless you got abs, i dont)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel
14. yel/wht fuel gauge
15. lt grn/red door switch
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
just put the GSR cluster in my teg so I know that it works just need to find out why its not working in my car (92 vx)
well what the hell I am really stumped, checked all the fuses, checked the harness, checked the wiring of the pins, and checked that cluster and all I get it a buzzing sound when I try to use the turn signals and the high beam light works nothing else?!?!?!
have you checked the ground? all the power wires? maybe one is crossed w/ another one? i know there are like 3 power wires, maybe you have a constant going to a switched or something.. umm.. did you use the integra plugs or the civic plugs? i had to go to a junk yard and cut the integra plugs and rewire to the chasis harness.. check all fuses agian, and go back over your steps.. soemtimes its easier to restart from the beginning..
ctr97
01-05-2003 04:49 PM
ATLienCivic
09-02-2002 06:26 PM
