problem with trunk!
problem with trunk!
ok so heres the problem i put the key into the trunk and turn and its SUPPOSED to pop up but it doesnt. it just turns as if there isnt a mechanism at all that opens it up. i got a del sol s so it doesnt come with the lever in the driver side so what am i supposed to do? i cant get my books and do my homework!!!
Re: (jerbear!)
there is no lever on the driver side?
mine does have a lever on the driver side though...
may be just turn your key and use your hand to pull it? since mine won't pop up by itself either since the spoiler is too heavy
there should be two little rubber bump stops in the back. all i did was back them out a bit until it did what it was supposed to do. dont back them out too much or youll get a gap.
Re: (Hart-n-Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hart-n-Sol »</TD></TR><TR><TD CLASS="quote">there should be two little rubber bump stops in the back. all i did was back them out a bit until it did what it was supposed to do. dont back them out too much or youll get a gap.</TD></TR></TABLE>
where would this be? on the sides of the back correct? and what do i need to use to do so?
and no it doesnt pop up when i push it up while turning the key
Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">
and no it doesnt pop up when i push it up while turning the key</TD></TR></TABLE>
when u pop the trunk they will be in the two corners (on the trunk) just turn with your hand and close and check. keep adjusting as neccesary. and yes 93 did not have an interior switch. u have to use your key.
the problem is when i turn the key the trunk doesnt pop up at all. i think the mechanism is broken is there a way to get inside without using a key?
hmm well thats a diff story all by itself. first of all im assuming its the right key and has worked before right? as far as getting into it u might be better off taking it down to honda and let them mess with it. i dont think u can remove the center window to gain access but i've never tried either. good luck man.
1 Post
Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">grrrr, do you think they gonna charge me any?</TD></TR></TABLE>
Well I highly doubt any dealership will diagnose a problem for free.
saltybeagle
04-13-2010 11:46 PM
k0rupt_ed
09-15-2007 01:37 PM
Yak BallZ
02-18-2006 12:36 PM
