problem with swap
problem with swap
ok so i started my swap and pulled the engine from my cx, i was planning on changing the water pump and timing belt on my new z6, but i cant pulleys off because the bolt wont loosen, i tried sticking a screwdriver in the fly wheel and using a breaker bar, heating it and soaking it down with bolt breaker stuff, and i tried using and impact wrench at 120 psi but no luck. what do i do now? i need to get this engine in?
Re: problem with swap (csxcx)
what did you use to heat it? i had problems getting bolts out on my swap.. i torched it and then let it soak in wd-40 overnight.. worked for me
Re: problem with swap (NY93CivicEx)
https://honda-tech.com/zerothread?id=1222655
this thread shows multiple ways to get the crank pulley off. i wouldn't advise a torch close to the crank seal.
Modified by mr. carpenter at 3:06 PM 4/24/2005
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csxcx »</TD></TR><TR><TD CLASS="quote">ok so i started my swap and pulled the engine from my cx, i was planning on changing the water pump and timing belt on my new z6, but i cant pulleys off because the bolt wont loosen, i tried sticking a screwdriver in the fly wheel and using a breaker bar, heating it and soaking it down with bolt breaker stuff, and i tried using and impact wrench at 120 psi but no luck. what do i do now? i need to get this engine in? </TD></TR></TABLE>
get a bigger impact
get a bigger impact
revhardEK
22
07-18-2012 08:13 AM
Charlie Moua
10
06-21-2004 04:13 PM
I Gotta Question
13
01-08-2004 07:00 PM
serious
13
09-23-2002 06:57 PM
