Problem Starting 1995 Civic
Hi Guys/Gals,
I have a friend that has a 1995 Honda Civic 1.5L 16-v and while cranking the engine it won't start. Does anyone have any ideas what this may be? |
Re: Problem Starting 1995 Civic (msvara)
does it turn over? check the distributer and rotor. may be bad causing it not to get spark. or maybe fuels not getting to the motor. check the fuse to the ecu/fuel. may be blown. https://honda-tech.com/forums/images...es/emsmile.gif
Listen to see if the fuel pump primes. Check for fuel, check for spark, check the main relay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msvara »</TD></TR><TR><TD CLASS="quote">Hi Guys/Gals,
I have a friend that has a 1995 Honda Civic 1.5L 16-v and while cranking the engine it won't start. Does anyone have any ideas what this may be?</TD></TR></TABLE> fuel, distributor, and maybe battery? not enough clutch? |
i would start with the battery and spark. Take the battery out and take it to a parts store and have them test it for ya.
