problem shifting into 1st gear
shifting from a complete stop into first gear is becoming a problem. it's like something is blocking the shifter from going into 1st gear.
my 99 civic dx has all of it's scheduled maintenance performed by honda and I change my oil every two thousand miles. This problem started happening recently and my car only has 57,000 miles. what could be causing this problem?
Re: problem shifting into 1st gear (control1200)
my friend had the same thing, didnt get it fixed and then tranny crapped out bout a month later, id get it checked
Re: (dampachi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dampachi »</TD></TR><TR><TD CLASS="quote">you guys have it lucky... i have it on first and reverse!</TD></TR></TABLE>
Same here.. i just let go of clutch and step on it again and put into gear.. seems to work.
Re: (Spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon »</TD></TR><TR><TD CLASS="quote">
Same here.. i just let go of clutch and step on it again and put into gear.. seems to work.</TD></TR></TABLE>
Yep, that's what I did. I'm going to change the syncro for my 5th gear since it grinds. I'm going to have them check it out to confirm what it could be in 1st gear.
Re: (dampachi)
I always had a problem shifting in reverse, but I was told by friends that civics are all like that.
but not being able to shift into first is starting to worry me, I really hope that it's not the transmission.
I guess it's a myth that honda trannys are super strong and able to handle large amounts of boost
Re: (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude »</TD></TR><TR><TD CLASS="quote">Have you tried changing your tranny oil yet? It will probably help some if you already havnt done that. </TD></TR></TABLE>
Yea i think it might be that too. Im having the same problem but it just feels like its not slippery enough in there. But if its not that then.....
Re: (dampachi)
you, me, and 85% of all hondas. heh
Broken 1-2 shifter fork.
Happens.
Bet $1,000 thatyou downshifted hard into first and snapped the leading edge of the fork off. Yank it and send the sucker to the Great Mr. Bone.
Stick
Happens.
Stick
Re: problem shifting into 1st gear (Tim the Stick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim the Stick »</TD></TR><TR><TD CLASS="quote">Broken 1-2 shifter fork.
Happens.
Stick</TD></TR></TABLE>
hahaha weRd! heard something about this also.. thats why i no longer let anyone drive my car.
Happens.
Solbros Owns Me
Re: problem shifting into 1st gear (Spoon)
When I threw a B16 tranny against his GSR engine....ad trouble shifting into first for about 20 miles....then it went in fine.
How about going into 2nd, and then into first....I bet that works fine
thashadow
09-15-2002 05:04 PM
