problem please give info
we took my friends 2000si to the track. we made 3 passes on his 17 in rims and on the last one he said the wheel started wobbling. ever since then it has been wobbling at about 30-60mph it feels like the axles are wobbling. i don't know if it is alinement or trans or what. i took it the first two passes and power shifted every gear so throw some guesses out. thanks
Re: problem please give info (chainsaw)
i am pretty sure they were tight but after the third run we put my 14 steelies on so i know those lugs are tight. thanks for the comments how do i check the axle without takin it out. he just broke one about 2 weeks ago . he has a jdm itr trans could his lsd be bad
Re: problem please give info (lsvinny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">did you throw a wheel weight?</TD></TR></TABLE>
no i don't have any where can i get one and it does it from both sides
Re: problem please give info (JSPECEX)
its the way they balance the wheels, but if you started out with none and it got worse thought out the day, then my guess would be your axles or hub bearings.
Chicano
11
01-19-2005 08:14 PM
