prelude type sh swap in ek ?
I would like to drop a sh motor into a 98 ek can it be done ...any help on the topic would be nice (tryed many searchs no luck) Thank's new B
Re: prelude type sh swap in ek ? (racer4life)
Press the link to Search. In the Search For line type in "H22A or H22A swap" then hit the Next button. If you cannot find the info there, then go back to the Search page and where is says Data Set change the window to Archived Topics. If you can't find an answer there then go to hybrid.honda-perf.org and post there.
Re: prelude type sh swap in ek ? (battlecat187)
I was told that u can't lower your car that much with a H22 swap can anyone confirm this and if so how low can u go anyone got pic's and what size rim'z u running
1 Post
1. learn how to spell
2. I dont think you can use a SH swap, as it has that traction control system
3. Its common sense you cant lower or "slizam" your car that much with an h22a because of the low exhaust manifold clearance.
DO A SEARCH tard'
DO A SEARCH tard'
doing an SH swap is another story though, 'cause your SH transmission is made to be used with an ATTS module, which would be a nightmare to get working in your car, and then you'd need custom axles.
if you get a complete SH swap, sell the tranny and ATTS module, and get a non-ATTS tranny. then you use an 90-93 accord (5-speed) intermediate shaft, and 90-93 integra (5-speed) axles. You'll need a mount kit to bolt the motor into your car, and for wiring i recommend you use your stock civic harness then add wires for knock, vtec, iab, and egr (if you want to run egr).
Good luck.
Re: prelude type sh swap in ek ? (YumVTEC)
ive got everything you need to put a h22 into an ek.
place racing mounts $550 (no cutting,hammering, or welding like the other kits)
Raxles custom axles-200
prelude shift linkage-100 (i dont know if you need it though)
pm me if interested
pm me if interested
