power windows i a 00 hatch?
hey what['s up I have a 00 si that is wrecked and I am going to swap everything into my hatch and I need any info if at all I want to install the cruise control the power doors and I have a body shop that is going to customize the sunroof! I need any info for this, what will work, what won't, and I greatly appreciate it! thanks
Re: power windows i a 00 hatch? (CR-V-tech)
you can use the harnesses.. but you're going to run into a problem with one of the plugs. on the si it's for power door locks.. and on the hatch the same wires are used for the rear wiper.
1 Post
you can transfer everything from 00 si to the hatch. you can either gut the doors or change the doors complete. you will need the floor harness from the si also
Re: power windows i a 00 hatch? (kyden)
hey what's up can u elaborate a little bit or are u not sure? but I would appreciate it if u could thanks, josh
here's a diagram of one of the plugs on the floor harness:
see where it says rear wiper for the hatch? the same wire on the coupes is for power door locks.
bump for more info, and thanks alot to everyone! I was wanting to know if I can keep my rear wipers or not, cuz kyden's diagram shows the wires to be on the same pin, and I would really like the power locks and the rear wiper to work! If I have to wire seperately or not?
1 Post
http://repo.jackmoves.com/album206
most of this information will help you out. the front and rear main harness clips are different though so you might need to figure the wiring out on those. the schematic posted above will probably help.
ok here's the scoop the floor harness swapped in fine and I also added the 3 extra wires for the rear wiper, I don't have the power locks for now and won't untill I swap the dashes and dash harness's and rewire the rear wiper! I got everything together and no workie, so I installed three fuses and the p/w relay and that fixed the problem! everything worked great! I was driving around town last night showing all of my friends and then at my last stop they just quit working?????? so now I'm confused there is a fuse under the hood for p/windows but they worked with out that one installed and then I put one in there and still nothing, i have checked all of the fuses and they are all in good shape! I think i'm gonna get a new master switch, cuz the windows were down on the doner car, possibly water damage! still not sure though
1 Post
when I did my swap I had the exact same thing happen and what it ended up being was the connection at the drivers door (the big grey clip with the rubber boot over it between the door harness and floor harness). I must not have had them connected to where they clicked and it worked itself loose. you might give that a try. its either that or your drivers side switch. those are the only 2 things that would cause that.
Uneekpinoysk8er
08-23-2006 05:14 PM
2000DX
09-21-2003 11:59 PM
xjohnx
07-14-2002 12:21 AM
