power windows for a 93 del sol si... what's the deal
i have a 93 del sol si and everything seems to work but the drivers side and pass. side windows the rear window rolls up and down perfectly with the switch on drivers side but neither of the two others work... when i hit the switch on either side to roll them down ( they are stuck in the up position) i hear a clickin sound that sounds like its coming from the lower part of the car like under the dash or under the car i have checked all fuses and everything i attempted to wire direct power to the passengers side window but i only got as far as taking the panel off and lookin at all the wires if i was to run direct power to the motor what wires would be positive and negative? thanks and cant wait for the help...
Re: power windows for a 93 del sol si... what's the deal (Kendawg386)
You have mulitiple fuses that run the power window module in the d/s door. You need to check if any fuses are blown first. #5, 7, 8, and 15 in the dash fuse panel.
If all of them are good you might have a bad module cause if you hear a clicking sound that tells me the switches are working.
Re: power windows for a 93 del sol si... what's the deal (150sol)
that's what i am thinking and the fact that it is both windows and not just one so i don't think that both motors would go out at the same time how can i test the module.
any help guys? this is a pretty big problem.. i also have another post about my fuel pump if anybody knows bout that stuff too... thanks
JC_1118
20
04-30-2021 07:00 AM
Neth
01-19-2018 02:14 PM
