power window wiring helpp
okay my power window regulator is damaged so i bought civic type r door htath as the regulator
the regulator on my normal ex door has 4 wires and the
civic type r power window regulator only has 2 i dont quite understand
the ex power window regulator has black red yellow and light blue
the civic type r power window regulator only has red blue and white blue
does anyone know how i should wire it out ??
if i hook the ex power window red to red blue and black to white blue to the civic type r
the window works but it only goes up but not down
basically i cant get the down function to work
so anyone has any idea?
Re: power window wiring helpp
The passenger window motor only has two wires.
If the ex power window red to red/blue and black to white/blue makes it go up, you need to reverse the polarity for it to go down. In other words, switch it to ex power window red to white/blue and black to red/blue. That should allow the window to go down.
so what i should do .. or at least i came up with is hook up red ( power) to both red/blue and white/blue and ground the black wire??
Are you working directly off the motor harness or off the plug? I set my power windows up directly off the power window harness, which is three wires on the driver motor and two on the passenger.
But I also set up individual switches since I will not be using stock door panels, and I also eliminated the one touch down function, as I don't like them.
im working directly with the plug on the harness? im working directly on the wire in the window and the plug on the regulator
fixed: i had to hooked the redwire to the blue and red, and the yellow wire to the blue and white,
the only bad thing is that i lost the auto function to the window , but thats no big deal
96civic808
12-13-2015 05:35 PM
pisetup
32
10-12-2014 08:52 PM
SlowB16
04-11-2013 04:08 AM
spnej1
16
03-03-2008 06:32 AM
