Power Window Problems
I have a power door conversion in my EG hatch from a coupe anyway my passenger window just stopped working, no sounds or anything when I try to roll it down from either switch I checked the fuses and they are good, and the relay is good since the driver side still works so I figure the motor died, but how do I get into the door to change it? I'm familiar with the process of how to get the regulator out but the process according to the FSM assumes I can roll down the window.
Re: Power Window Problems
Anyone? The window is stuck all the way up, and when I remove the door panel I can't reach the regulator bolts, again this is on an EG hatch, with doors from an eg coupe
Bump anyone else? there has to be a way to lower the window regulator but honda wants $100 just to look at it.
Have you tried to have someone push the switch and you push it down manually (like door open with a hand on each side of the glass)?
take the panel off and try hitting the motor or about where the motor is at, with a hammer. Don't try to kill it, just tap it a few times. It will either work, or it won't
Tomas P
04-06-2012 12:06 AM
mavvrik
03-31-2011 05:36 PM
