Power Steering - Thoughts and Questions
Old 08-05-2005, 02:34 PM
noTe's Avatar
Default Power Steering - Thoughts and Questions
I searched and didn't really come up with much.
I recently bought a CX and I'm not used to not having power steering. I have a friend who is willing to trade me racks if I want power steering.
The question is, what are the benefits of not having power steering other than having better feeling of the car at highway speeds? Those of you who do autocross or road course racing, do you have power steering?
Old 08-05-2005, 05:08 PM
noTe's Avatar
Bump.
Old 08-05-2005, 05:16 PM
nighttrain33's Avatar
Default Re: (noTe)
I don't know if this helps or not, but I don't do autox. I do have a hard suspension on and I do some hard cornering. I do fine without it, and I have a much heavier car than you do. The only difference may be if you are small. I am close to 6 feet tall and weigh over 200 lbs.
From anyone that I know that has a cx, you really don't need it. The cars aren't that heavy and not having power steering takes even less weight off.
-Shane
Old 08-05-2005, 05:18 PM
Default Re: (nighttrain33)
*edit* I have a friend with a pretty similar setup on his cx minus the suspension and he he only weighs about 140 and he doesn't have p/s. Hasn't complained a day since he got his car.
-Shane
Old 08-05-2005, 05:30 PM
noTe's Avatar
I'm about the same height and weight as you actually. The car is bone stock so maybe some better tires and suspension will make it easier to get used to it. Thanks for the help though.
If anyone else has any comments, please add.
Old 08-05-2005, 05:37 PM
SirRevvs's Avatar
Default Re: (noTe)
I've heard that the power steering system doesn't even do anything after 15 mph?
Old 08-05-2005, 05:39 PM
Default Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that the power steering system doesn't even do anything after 15 mph?</TD></TR></TABLE>
It does, it gives less road feel . It still does a little, but it is not very noticible at all.
-Shane
Old 08-05-2005, 07:00 PM
JoKarma's Avatar
Default Re: Power Steering - Thoughts and Questions (noTe)
Well it would add weight, which does you no good. You have a relatively short wheelbase which basically eliminates any real need for power-steering.
I had a CRX for a two years, if its awkward to you know, just give it a couple months. You wont notice it eventually.
Old 08-05-2005, 07:06 PM
cxSHOE's Avatar
ive had a cx with no power steering, fine if the car is moving, sucks in parking lots, and pulling out between two cars when parked on the side walk. or doing a 3 point turn.
now i have an si with power. much better ofcoarse. but i wouldnt waste the time tearing down and swapping arms, let alone adding stuff to the engine such as the pump.
too much work for me for better steering.
power steering= one hand turns at dead stop
none power= two hand HARD turning at dead stop
Old 08-05-2005, 07:11 PM
blackbmagic's Avatar
Default Re: Power Steering - Thoughts and Questions (cxSHOE)
try this https://honda-tech.com/zerothread?id=1328168 might help
Old 08-06-2005, 08:59 AM
noTe's Avatar
Default Re: Power Steering - Thoughts and Questions (blackbmagic)
Thanks, that linked helped me. I didn't see if when I searched.
This car is going to be my daily driver and I'll be going to college with it and I'm sure I'm going to have to parallel park often.. that is what I'm really thinking about.
Old 08-06-2005, 10:20 AM
banned
s-tech's Avatar
I like it cause the girlies "can't turn the wheel", makes em like my powerfull hands and arms
Old 08-07-2005, 09:49 AM
truebeliever's Avatar
Randy quit being a ***** and get some muscles. i like pierced nipples as much as the next guy but come on its not hard to turn at all you just have to put some of that tough guy into it.
Old 08-07-2005, 10:13 AM
inane's Avatar
i think if you want to do autocross it would probably benefit your times to have power steering... power steering may not do anything above 15mph for some people... but when youre taking turns you can really feel it... like on freeway ramps that connect to another freeway and its those circle turns that are sharp... yeah... you can really feel it without powersteering when going 60mph... you have to fight the steering.... with power steering you just turn the wheel and dont even feel how much force youre really putting on the car...
i removed power steering from my car, but i dont do autocross... if i did, i would have PS :D
Old 08-07-2005, 11:03 AM
Kyles ej1's Avatar
Default Re: Power Steering - Thoughts and Questions (inane)
i &lt;3 my ps on my ex!
i removed the belt for a couple of days just to see what its like and u can definatley feel the road better but i like the luxery of 1 hand steering. unless your 5'1" or a girl i dont see how it would be a problem. just give it a couple of weeks and youll get use to it
Old 08-08-2005, 12:27 PM
JoKarma's Avatar
Thats another good point. It builds a bit of muscle somewhere in the arms. Like I said, after so long, you just dont notice it anymore.
vtak-maniac
04-23-2010 10:28 AM
shotime
Suspension & Brakes
08-08-2009 10:24 AM
ridethebull
06-27-2006 03:21 PM
meagainsttheworld
16
04-11-2006 06:04 AM
mr2
21
10-27-2001 01:47 AM
Quick Reply: Power Steering - Thoughts and Questions
